2016 15" MacBook Pro RP460 + Vega-FE@32Gbps-TB3 (Mantiz Venus) + macOS10.13.2 [Shinra]^ // using 600W PSU
Shinra
(@shinra)
November 21, 2017 7:04 am
Hi Guys,
I want to share my configure of the AMD Vega FE.
IMG 8699
In 10.13.2 beta, Vega's driver is all good for most applications, the only problem is the fan speed.
IMG 2286
However, the Vega FE in the system still shows as AMD RX xxx 16G.
These following test is testing under internal screen on.
Valley:
IMG 1295
LuxMark:
IMG 2893
BrunceX:
IMG 6913
Moreover, if we are using the original PSU(550W), Mantiz Venue will power off when I play around 2mins games (Hero of storms) or I do some heavy rending(Final Cut Pro X).
So I update the PSU to 600W one. It works very good, no any power off problem.
Audio: Audio via DisplayPort shows in sound preference, but these is no sound output via DisplayPort.
Hot plug: Yes, when thunderbolt cable connect, log off and log in can use the eGPU.
That's all I have tested. Thanks for reading.
Edited: 6 months  ago
2016 15" MacBook Pro 2016 + Vega-FE@32Gbps-TB3 (Mantiz Venus) + MacOs 10.13.2 beta // using 600W PSU
theitsage liked
theitsage
November 21, 2017 3:43 pm
@Shinra thank you for the implementation guide with the Vega FE. Once Apple releases the iMac Pro, the issues you encounter should be resolved. This is a sweet setup!
51 external GPU build guides
P-Mac
(@p-mac)
December 4, 2017 2:55 am
Hi, can you confirm that the card is stable in FCP X? Thinking about upgrading to this card.
2016 15" MacBook Pro RP460 + RX Vega64 @32Gbps-TB32 (Asus XG Station 2) + macOS10.13.4
VG248QE 1080p 144hz // Logitech G602 / SteelSeries QcK+ & Drevo Gramr TKL, Blues // Scarlett 2i4 + JBL Linear Spatial Reference 305's
Juan C. Yunis
(@juan_c_yunis)
December 6, 2017 10:59 pm
Thank you for this, so 600W was enough? is it SFX? do you think that maybe upgrading to a 650W SFX would be better? and my final question, do you have to do the login and logout trick, does it work if you boot the MBP with the eGPU connected.
Edited: 5 months  ago
2017 MBP 15″ RP560 + Mantiz Venus + AMD Radeon Pro VEGA Frontier Edition
