2016 14" Razer Blade (GTX 1060/i7-6700HQ) + GTX1080@32Gbps-TB3 (AKiTiO Node) + Win10 [rykys]^
rykys
(@rykys)
April 10, 2017 3:56 pm
PC: 2016 14″ Razer Blade (GTX 1060/i7-6700HQ)
eGPU: AKiTiO Node (Thunderbolt 3)
GPU:  ASUS ROG STRIX-GTX1080-A8G-GAMING
The AKiTiO Node was plug and play with the 2016 Razer Blade.  I upgraded the eGPU firmware before I received the graphics card, so I don’t have before and after unfortunately…  I did see quite a bit of improvement over the built-in GTX 1060 at both 1080p and 1440p:
GTX 1060:
Unigine Heaven Benchmark   1080p   GTX 1060
Unigine Heaven Benchmark   1440p   GTX 1060
GTX 1080:
Unigine Heaven Benchmark   1080p   GTX 1080
Unigine Heaven Benchmark   1440p   GTX 1080
These benchmarks were taken using an external monitor.
Edited: 11 months  ago
enjoy, Yukikaze, theitsage and 1 people liked
Klasegpu
(@klasegpu)
April 10, 2017 5:17 pm
That looks really good, have you tried running Firestrike benchmark too?
Intel Nuc Skull Canyon
Akitio Node
Gigabyte gtx 1080
rykys
(@rykys)
April 10, 2017 8:18 pm
I will run them at some point this week when I get a minute.  I was getting ~9400 with the built-in GTX 1060 in my Blade.  The physics score with the i7-6700HQ brings down the Fire Strike score quite a bit.  I haven’t seen that translate to in game with the 1080 though…
Klasegpu
(@klasegpu)
April 10, 2017 9:22 pm
Posted by: rykys
Alright, you alleviated some concern I had before opening the package 🙂
Akitio Node
Gigabyte gtx 1080
rykys
(@rykys)
April 11, 2017 11:10 pm
Posted by: Klasegpu
Here are the Fire Strike and Time Spy results:
Time Spy
Fire Strike
Note that the CPU score brings the overall number down quite a bit.  I got almost double the graphics score on Time Spy with the 1080 (6745) than I got with the 1060 (3472).  I got around 6500 points higher on the Fire Strike graphics score using the 1080 vs the 1060.  Overall I would say I’m happy with the performance of the 1080 and Node.  For 1440p gaming I’ve noticed a large increase in FPS with the 1080.
enjoy liked
enjoy
(@enjoy)
April 14, 2017 12:14 am
Great setup 🙂 Can you run the eGPU on your Internal Display and to run Heaven again with the same settings ?
 MacBook Pro (Retina, 15-inch, Later 2013) 3.2GHz Quad Core Intel i7-4750HQ / 8 GB 1600 MHz DDR3 / 256GB SSD + 1TB
julianpoyo
(@julianpoyo)
May 16, 2017 1:24 am
Were you able to get the internal display to work with Optimus? I can’t seem to get Optimus to choose the eGPU over the dGPU (1060).
dreamcat4
(@dreamcat4)
June 7, 2017 8:29 pm
Hi there. Do you know if the Razer Blade has the TB3 controller wired direct to the CPU. Or is it attached to the PCH like most other laptops?
This information, (the internal pci-e wiring) can usually be seen in HWInfo64.exe or similar programs. Many thanks.
Working
Please Login or Register
