System;
Asus K55VD
i5-3210M
intelHD4000/GeForce 610M
BenQ 24" XL2411 ZOWIE 144Hz 1ms
eGPU;
Asus GTX 970 Strix OC 4GB
Home made case;
* V8.4 EXP GDC Mini PCIe Version
* Asus GTX 970 Strix OC 4GB
* 350 Watt PSU
* 12 V Fan
* Blue Color Led
System is working very fine, I can play games are the range on high-ultra settings internal or external monitor.
GeForce 610M Unigine Heaven Valley Benchmark (8-12 fps);
eGPU GTX970 FurMark Test on internal monitor
Resolution 1366x768 and 1920x1080
eGPU GTX970 Unigine Heaven Valley Benchmark (60-80 fps)
eGPU GTX970 Time Spy and Fire Strike Benchmarks Results;
Comparative Benchmarks wtih GTX 1060;
Hello bay teknik. I have the same laptop. How did you do to disable the GeForce 610m graphic card?. Thanks
.hi, i done this steps.
- connect egpu dock on my laptop.
- connect GPU on dock and power connections
- start windows safe mode (but no running egpu no power)
- run DDU and i removed 610m drivers
- start windows normally
- I setup actual nvidia driver for my GPU
and I saw something on device manager. after driver installation 610m and GTX970 were installed together. I disabled 610m on device manager and restarted the system.
and system works no problem.
can u tell me if it will work on my laptop having same cpu 3210M , But i have Radeon hd 7670m as a dedicated gpu
.Hello , can I install a Radeon HD 7870 Gigabyte on my Asus K55VD? It has The exact same gpu , gt 610m 2 gb , 8 gigs of ram and a i7 3630qm. Thanks!
.I have a problem. I had everything working just fine and then I decided to format my PC. After the format the egpu won't even get recognized in device manager and I can't get it to work. Any help would be appreciated!
.Hi, Just wondering how much bottleneck you get on the 970?
Thanks, Salltyy8
