2012 Intel NUC33217CK [3rd,2C,U] + HD 7570 @ 4Gbps-mPCIe2 (PCE164P-N03) + Win10...
2012 Intel NUC33217CK [3rd,2C,U] + HD 7570 @ 4Gbps-mPCIe2 (PCE164P-N03) + Win10 [Yukikaze]
Yukikaze
(@yukikaze)
Prominent Member Moderator
Posting this here so it appears in the implementations table. The original post is found here.
The build summary is as follows:
  • CPU: CPU: i3 3217U
  • Motherboard: Intel DC33217CK NUC Board
  • Case: Silverstone PT14 Aluminum NUC Case
  • Memory: 2x4Gb DDR3 1333Mhz
  • Storage: BP4e V2 120GB mSATA SSD
  • Power Supply: FSP 65W (19V, 3.42A) NUC PSU + AKiTiO Thunder2 stock 60W power supply (12V, 5A) for the eGPU
  • OS: Windows 10 Professional 64-bit
  • eGPU Enclosure: PCIE164P-N03 mPCIe to PCIe Adapter (barrel plug version)
  • eGPU: Low-Profile Dell OEM HD7570 1GB GDDR5
3RYL, itsage and nando4 liked
