Good Day Everyone..
After spending weeks on this problem I have found a solution.
I just want to post an Update on this issue.
I managed to get this to work on Both PC and MAC.
Here are my Specs:
Macpro Late 2013 128GB
OS:
- Mac: OSX Mojave 14.6
- Pc: Windows 1903
Graphic Cards
- AMD Firepro D500 (FireGL V)
- Blackmagic Pro EGPU Radeon Pro 580 8Gb
- Razer core X RX480
Displays:
- 32" BENQ EW327OU
- LG HDR 4K
- Wacom Cintiq 13 HD
This is how I did it.
I connected the Blackmagic Egpu into to the Mac using a genuine Thunderbolt 2 to USB -C Adapter
I downloaded Purge Wranger.
GitHub - mayankk2308/purge-wrangler: AMD & NVIDIA eGPUs for all Thunderbolt Macs.
I ran TERMINAL and I installed Purge Wrangler. I selected AMD as the driver and followed the installation procedures.
After that I restarted the computer and connected the Blackmagic egpu to the bottom-right port of the thunderbolt 2 port and it worked perfectly with the Mac.
With Windows.
After trying different types of windows version and trying different approaches with DSDT etc, none of it worked.
So I downloaded the 1903 Windows version OS build 18362.30. I installed windows using bootcamp.
https://archive.org/details/windows-10-1903-x-64
When setting up windows its important for you to participate in the Windows insider Preview. This is really important for this to work.
It took some time (10-15mins) for Insider to complete installation.
After installation of windows, I download bootcampdrivers.
BootCampDrivers.com: Turbo-charged AMD graphics drivers for Mac BootCamp users.
The driver that worked for me was the NOV 2019 Blue edition.
After following the installation procedures in Safe Mode, I restarted using the computer into PC and installed the Bootcamp drivers Nov 2019 Blue Drivers.
I encountered and Error 12. The EGPU was not even recognised.
So I went to the device manager and I disabled the following PCL-to-PCL Bridges:
Pictures below.
After disabling the PCL bridges, I went to the Windows Insider Program. This would not work without receiving updates
I restarted and Voila. It worked.
I connected all my devices including the Wacom CINTIQ13HD, OCULUS CV1, ETC and it all worked perfectly.
I ran Radeon Pro Setting and the picture is displayed below.
However, I noticed that the windows only recognised one of the AMD FIREPRO D500 card.
I hope this helps anyone facing the same issues with the same device.
2013 Mac Pro (FP D500 x2) [3rd,12C,E] + RP 580 @ 16Gbps-TB2>TB3 (Blackmagic eGPU) + macOS 10.14.6 & Win10 1903 [build link]
@fobeats_instrumentals, thank you for your information. Would you mind completing the build template to capture all pertinent info our users seek from build guides?
2015 15" Dell Precision 7510 (Q M1000M) [6th,4C,H] + GTX 1080 Ti @ 32Gbps-M.2 (ADT-Link R43SG) + Win10 1803 // compares M.2 vs TB3 performance inc unoptimized H-CPU BIOS [build link]
