November 2, 2020 7:06 pm
System
- MacBook Pro (Retina, 15-inch, Mid 2014)
- macOS Big Sur 11.0.1 Beta
- CPU Thermal Repaste, Grizzly Kryonaut
- GPU Thermal Repaste, Grizzly Kryonaut
eGPU
Installation
- Disable CSRUTIL and AUTHENTICATE-ROOT on system recovery terminal.
- Install PurgeWrangler with support for AMD legacy devices.
- Reboot.
- Load system and after CPU has settled then plug-in TB1(2) cable.
Statistics
2020-11-02 , 11:04:59
2014 15" MacBook Pro [4th,4C,H] + RX 5700 @ 16Gbps-TB2>TB3 (Razer Core X Chroma) + macOS 11.0 [build link]
November 24, 2020 8:21 pm
Hello! What processor and internal GPU does your macbook have? I am planning to do the same setup with macbook 2014 750m, akitio thuder 2 and Radeon Vega 8gb. I don’t understand yet whether the components will fit together.
Macbook mgxc2 (2014 with 750m), akitio thunder2, GTX 970 by NVidia, Corsair VS550 PSU, External monitor Benq 3201 4k
December 23, 2020 8:53 am
Did you also try this on the "official" Big Sur release?
I'm planning to build a similar setup for my 2015 MacBook Pro.
