2016 15" MacBook Pro RP460 + RX Vega64 @...
2016 15" MacBook Pro RP460 + RX Vega64 @16Gbps-TB3>TB2 (AKiTiO Thunder2 via TB3->TB2 adapter) + macOS10.13.2 [P-Mac]
P-Mac
(@p-mac)
Jan 12, 2018 3:47 am
IMG 1812new
DotPusher IV
switch-hitter.
The gist of this story is that I was sick of NVIDIA's sub-par macOS drivers causing the majority of my old Titan Xp's teraflops to go to waste in my FCPX workflow. It was regularly running the BruceX benchmark in ~45 seconds, significantly slower than it should be running. So I figured I'd get as close to an "approved" setup as I could.
Enter the RX Vega64 by being on sale with only one left at Newegg, and their warehouse being a quick drive away from my house for will-call pickup. Add to that the 2016 MBP's price being cut by B&H by a thousand dollars and...yeah. Temptation bit hard.
Hardware
Software
  • macOS High Sierra, 10.13.2 (unmodified, SIP on)
  • macOS High Sierra Beta Update, 10.13.4b2 (unmodified, SIP on)
Build Instructions
See the link under "heavily modified" to see what I've done to frankenstein the Thunder2 to get it to run a GPU, as well as to fit it into the ammo can case. That's the hard part. The macOS experience is hilariously easy:
Boot laptop to login screen, close lid, plug in power, USB peripherals hub, and then eGPU in that order.
The screen comes up, I log in, and I'm up and running. When I want to undock from the desk, I just make sure no apps are running on the eGPU (easily checkable via iStat Menus), and simply unplug everything. Most of the time, this works fine, and I can use the laptop normally.
Windows is another story; I'll update this section once I get it up and running, currently dealing with Error 12 and haven't had time to troubleshoot it lately.
Results
EDIT: 10.13.4 betas are looking promising. Hot-plugging works, "closed clamshell" mode works, fan speed issue on Vega64 fixed. Can't wait for public release.
FCPX performance is blisteringly fast. Remember that ~45sec BruceX benchmark from before? 18 seconds now.
LuxMark 3.1 (luxball scene) score: 24,368.
Geekbench 4 compute: 181,610, compared to my Titan Xp's 94,025 in macOS.
Haven't done any OpenGL benchmarks mainly because the numbers will be worse than the TXp (heh) and I'm not really interested in OGL perf under macOS anyway. It's all about compute, baby.
IMG 1810new2
I think I'm liking the AMD / Apple ecosystem now. All I gotta do next is get into a TB3 chassis, but I'm glad the laptop is ready for the plethora of TB3 options that are out (and are coming out in the future).
My only regret is how damned cool the TXp's shroud looked in the case...but Vega's just so much more useful until NVIDIA gets their act together.
2016 15" MacBook Pro + Vega64 w/ Eiswolf GPX Pro LC
MAG341CQ 34" Ultrawide // Logitech G900 & HyperX Alloy FPS Pro (MX Blues) // Scarlett 2i4 + Yamaha HS7
goalque, nando4, Flint Ironstag and 1 people liked
simonasher
(@simonasher)
Jan 12, 2018 7:42 pm
Super interested in this setup. Currently running a MacBook Pro w/touchbar + 1080ti + Akitio Node over TB3 setup. Thinking about switching to a Vega RX 64 for a speed boost, but I'm running a Premiere workstation. I was sold on the CUDA support for a while, but seeing numbers from the Vega just makes me think it will have much higher overall performance in Premiere and Davinci Resolve. Would you be able to test either one of those??
2017 MBP/TB - Akitio Node + 1080ti - 10.13.5
P-Mac
(@p-mac)
Jan 12, 2018 8:16 pm
Posted by: simonasher
I have the latest Premiere CC installed as well as Resolve Lite. Anything in particular you'd like me to test? Any way to get a consistent benchmark going?
simonasher
(@simonasher)
Jan 12, 2018 8:55 pm
I wish I had a good answer to that. Got any 6k R3Ds you could put on 30 second timeline and apply some luts and color correction on and see how long it exports?
P-Mac liked
theitsage
Famed Member Admin
Jan 13, 2018 3:43 pm
Very nice work, @p-mac! How's cooling with the Vega 64 in your ammo box? It tends to run hot in my experience so keep an eye on that.
94 external GPU build guides
(@agris)
Jan 15, 2018 6:30 am
I love the poster on Your wall! 😀
Have you tested the card in After Effects, Photoshop, Illustrator, Premiere?
MBP 15' mid 2015
John_Petrucci
(@john_petrucci)
Jan 31, 2018 2:29 pm
Hello, Akitio Thunder 2 is natively recognized in High Sierra???
the only certified and recognized TI83 chipset in the thunderbolt 3 boxes??
STAFF eGPU.it
P-Mac
(@p-mac)
Feb 9, 2018 9:10 am
@simonasher Sorry, haven't gotten around to providing you export times yet. Trying to find a way to make this consistent for you to be able to test as well, I would like to upload a footage sample along with the same project file so that you can see and test for yourself what the difference in export speed would be.
@agris Thanks, haha, I read about it in a (great) profile of Jony Ive by The New Yorker. As far as CC apps, all working fine. I rely on those apps (sans Premiere) on a daily basis for work.
@john_petrucci Yes, the Akitio Thunder2 is recognized natively in High Sierra. I'm using the official Apple TB3 - TB2 bi-directional adapter. As far as I can tell, High Sierra is treating this like a "proper" External GPU: in System Profiler, the Vega64 shows "External GPU" under Type. The system does not appear to be treating it differently at all compared to a certified TB3 enclosure.
