2017 15" MacBook Pro (RP560) [7th,4C,H] + GTX 1080 Ti @ 32Gbps-TB3 (AKiTiO Node ...
2017 15" MacBook Pro (RP560) [7th,4C,H] + GTX 1080 Ti @ 32Gbps-TB3 (AKiTiO Node Pro) + Win10 [Glenn Aitken] // modded, water cooled
(@glenn_aitken)
MacBook Pro (15-inch, 2017)
3.1 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Radeon Pro 560 4096 MB
Intel HD Graphics 630 1536 MB
High Sierra 10.13.4 (17E202)
NVidia 387.10.10.10.30.107
Akitio Node Pro Thunderbolt 3 Enclosure
Zotac Geforce GTX1080 Ti 11GB
Hardware pictures
IMG 3442
IMG 0926
Used Automated Script thanks to Fr34k and Goalque. Was using temporary script on earlier version of high Sierra, but simple to update and worked perfectly.
Geekbench4 CUDA: 243701 (iM)
Screen Shot 2018 05 13 at 14.37.39
Screen Shot 2018 05 13 at 14.33.21
Screen Shot 2018 05 13 at 14.20.04
Screen Shot 2018 05 13 at 14.18.47
Screen Shot 2018 05 13 at 14.16.52
Screen Shot 2018 05 13 at 14.16.31
Screen Shot 2018 05 13 at 14.16.12
Very impressive increase in rendering speed of 4k, 6k and 10k video in premiere pro and Davinci Resolve 14. As long as using internal SSD, I can run full resolution video playback in timelines with no skipping. Using external drives causes bottleneck.
Screen Shot 2018 05 12 at 17.40.41
Screen Shot 2018 05 12 at 17.27.32
Screen Shot 2018 05 12 at 17.27.01
Screen Shot 2018 05 12 at 17.26.41
nando4, fr34k and goalque liked
(@kristian_martin)
Hi. If you have a moment to spare, can you run the SteamVR Performance test? I have this exact laptop and am looking at a solution to run the HTC Vive Pro. Thanks!
Sam.mcbride
(@sam-mcbride)
Hi! I have the exact same set up except I have a Mantiz Venus v2, but my question is, can you run this script on Mac OS Mojave? or does it have to be done on high Sierra 10.13 (I already updated and don't really want to backtrack unless its necessary)
