2017 13" MacBook Pro [7th,2C,U] + GTX 1080 Ti @ 32Gbps-TB3 (Sonnet Breakaway 650...
2017 13" MacBook Pro [7th,2C,U] + GTX 1080 Ti @ 32Gbps-TB3 (Sonnet Breakaway 650) + macOS 10.13.6 & Win10 [neaumusic]
neaumusic
(@neaumusic)
2017 Macbook Pro (No Touchbar)
Intel i5-7360U (2.3ghz - 3.6ghz dual core 15W TDP)
iGPU: Intel Iris Plus Graphics 640
dGPU: none
macOS 10.13.6
Enclosure: Akitio Node Pro
Enclosure: Sonnet eGFX Breakaway 650W (Firmware version 25.1)
Nvidia GTX 1080TI OC ROG STRIX
2m CHOETECH active TB3 cable, seems to work flawlessly
1TB SSD Samsung T5
  • 100GB exFAT --> NTFS via VMWare Fusion (Windows + Restore Points)
  • 50GB APFS Time Machine backup (macOS)
  • 850GB exFAT (Z:) SSD SHARED for games and a full Windows Dropbox backup
256GB Mac Internal SSD
  • Selective sync Dropbox (separate from Windows external Dropbox)
  • Applications etc.
Hardware pictures
(picture is before rEFInd "spoof os x version" to fix flickering logo and screen glitches)
Thunderbolt, Nvidia, eGPU, Boot Camp
For macOS:
Simply followed GitHub macOS-eGPU instructions, making sure to follow them directly.
If you get black screen, unplug DisplayPort to monitor, shut down, unplug eGPU, plug eGPU when on Desktop, and possibly log out/in
Lack of DirectX support makes it pointless, I manually plug HDMI to usb hub and remove eGPU before power on
For Windows:
This took a long time, and by now I'd reinstalled everything 5x times and thought I possibly bricked my internal display (LCD burn-in logo).
I recommend getting everything from this checklist (I recommend Downloads on an external drive in case of fresh install)
  • Win10_1803_English_x64.iso
  • Windows Support software (from Boot Camp app menus)
  • Intel Thunderbolt Driver NUC software 17.x+
  • DDU (Display Driver Uninstaller)
  • Nvidia 1080TI x64 driver
  • rEFInd from SourceForge (open-source contribution, unlocks Intel iGPU firmware on bootload screen)
  • VMWare Fusion / WinToUSB.exe for Windows To Go (external SSD) see
  • Unigine Heaven (benchmark)
  • HWiNFO64 (hardware info, if you need it)
  1. Install rEFInd, uncomment "spoof os x version" in refind.conf after install - might have to run `mountesp` to view the ESP partition in Devices
  2. Install Windows with kb/mouse attached
  3. Install Boot Camp drivers (Windows Support)
  4. Install Intel Thunderbolt 17.x+ to recognize enclosure
  5. System Restore Point. Just do it.
  6. Boot into Windows Safe Mode (Restart holding Shift -> ... -> Safe Mode, Option boot on restart)
  7. DDU clean and restart (make sure eGPU stays unattached, also disconnect usb hub HDMI if any)
  8. Option boot to Windows (if you have rEFInd already set up, it would spoof os x but you don't want to yet)
  9. Plug in eGPU, install Nvidia driver
  10. On restart, just let rEFInd load up and everything should work beautifully!
    rEFInd is open-source, activates integrated graphics to manage internal display, and prevents serious problems
  11. Display Settings -> only show on monitor 2
  12. Nvidia Control Panel -> enable 165hz and Gsync
To enable external (Z:) SSD SHARED in Windows 10
  1. right click Start button -> Disk Management -> delete and re-add the exFAT partition via right click
  2. remove hidden attribute, Run -> `diskpart` -> `list volume` -> `select volume n` -> `attributes volume clear hidden` -> `exit`
1440p medium-high CPU settings (without usb hub HDMI plugged in -- definitely bogs down system)
Unigine Heaven (relies on DirectX)
macOS: 7-10FPS
Boot Camp: 130-150FPS
PUBG
Boot Camp: 70-100FPS
League Of Legends
Boot Camp: 130-230FPS
Rocket League
Boot Camp: 165FPS
Chivalry Medieval Warfare
Boot Camp: 96-120FPS (UDKEngine.ini "smooth" to unlock FPS, see steam groups "thechivclub")
Originally had Akitio Node Pro, but couldn't get things to work correctly. Not sure if user error or I had a defective unit, but I could only get the enclosure recognized, not the card itself.
To save a lot of time, I didn't install Dropbox, but ultimately made sure to create Time Machine backup and Restore Points at every major step.
The Sonnet is amazing, very quiet when inactive. I tend to unplug at night (strange PSU charging up/down sound), and I'm testing a longer cable (2 meter CHOETECH cable TB3 for $50)
2017/2018 Macbook 15" + Razer Core X + Vega 56 (overclocked without eGPU cover)
2017 Macbook 13" + Sonnet 650W + 1080TI OC Strix
2017 15" MacBook Pro (RX555) [7th,4C,H] + RX Vega 56 @ 32Gbps-TB3 (Razer Core X) + macOS 10.14.6 & Win10 [build link]
itsage and nando4 liked
Noble Member Moderator
Care to share your PUBG settings? I'm getting 60fps on highish settings @1440 with a 1070... thinking upgrading might not be worth it if you are playing at 1080...
(@alessandro_fauth)
@neaumusic hi! how has your cable experience been with the Choetech active cable? is it still working?
This post was modified 2 weeks ago
