2018 13" MacBook Pro [8th,4C,U] + Radeon VII @ 32Gbps-TB3 (Mantiz Venus) + macOS...
2018 13" MacBook Pro [8th,4C,U] + Radeon VII @ 32Gbps-TB3 (Mantiz Venus) + macOS 10.15 [ikir]
ikir
 ikir
(@ikir)
Prominent Member
Hi guys, this is my build since few months, started with Mojave and now with Catalina. The system is very stable, Radeon VII is super fast for both for and gaming. The infamous fan speed issue is not a problem for me because I simply doesn't let my Mac sleep, I continue to bring with me everyday, it is always on machine for me.
I've published some cool videos about Radeon VII on my Italian website and YouTube channel, still worth to see it for non Italian speakers too at least the benchmark charts 😛
Radeon VII, awesome looking GPU
RadeonVII3 300x225
RadeonVII2 300x225
My desk, the first photo is old indeed, I will publish the update desk...
IMG 0371
IMG 2090
Radeon VII vs other 3 eGPUs
Article: https://www.egpu.it/radeon-vii-egpu-su-macos/
Rise of the Tomb Raider (Metal) 1080p high settings
eGPU bench rvii rise 600x369
With and without eGPU: Final Cut Pro X and Fortnite
Article: https://www.egpu.it/con-e-senza-egpu-videomaking-con-final-cut-pro-x-gaming-con-fortnite/
Final Cut Pro X export (seconds)
eGPU bench FCPX 600x369
my awesome Radeon VII eGPU
nando4 and itsage liked
Lrtn
 Lrtn
(@lrtn)
How did you get Fortnite run that stable in MacOS?
ikir
 ikir
(@ikir)
Prominent Member
Posted by: @lrtn
Not playing it much anymore, but I got no crashes during the benchmarks.
omardesu
(@omardesu)
@ikir What’s your definition of stable?  It looks pretty smooth but I did see a lag spike where the FPS drops for a split second.  This is totally noticeable during gameplay and is pretty common which makes playing Fortnite on MacOs a no-go for me.  The optimization of the game on MacOs is nowhere near as good as Windows, so that’s why I choose to play on Bootcamp w/out eGPU on my 2016 15” MBP.
Mini ITX Build in Dan A4 Case
2016 15" MacBook Pro (RP450) [6th,4C,H] + RX Vega 56 @ 32Gbps-TB3 (ASUS XG Station Pro) + macOS 10.14.4 & Win10 [build link]
@lrtn @omardesu
I tested fortnight on my set up as well as having the eGPU connected to a TV (so direct GPU connection unlike my usual set up) and Fortnite was horrible and barely playable (according to my 12 year old Nephew who is good at it) due to massive FPS drops and random lag. I've read its a known issue with the game in macOS.
ikir
 ikir
(@ikir)
Prominent Member
The random stutter (not lag) happens during the first loading of  assets as far I noticed in the past.
The game is stable I got no crashes or freezes.
It happens at the start but it also happens in game too... barely playable I would say.
rawwd
(@rawwd)
@ikir Are you running 10.14.5? I am on 10.14.6 and nothing shows up in my menu bar to tell me that my eGPU is connected properly.
MacBook Pro 15" Touchbar 2016, 2,9 GHz Intel Core i7 (I7-6700HQ) quadcore, 1TB SSD
16 GB 2133 MHz LPDDR3 RAM, Intel HD Graphics 530 1536 MB, AMD Radeon Pro 460 4 MB
Identifiers: Late 2016 15" (Touch Bar) - MLH32LL/A* - MacBookPro13,3 - A1707 - 3072
macOS Mojave 10.14.6 (Oct 2019)
Enclosure: Razer Core X (Oct 2019)
GFX Card: Gigabyte AMD Radeon VII HBM2 16 GB (Oct 2019)
ikir
 ikir
(@ikir)
Prominent Member
Posted by: @rawwd
I was on 10.14.5 without particular issue, now I'm on 10.15. it is natively supported, you don't need drivers or script. Thunderbolt 3 is plug&play.
Is your monitor connected to eGPU? Are you using a TB3 cable? Does you eGPU box have enough power to drive the beast? Does Radeon VII's lights turn on?
Posted by: @eightarmedpet
I don't play since a while, but I remember it happening only during the first loadings, after a while it is smooth.
rawwd
(@rawwd)
@ikir
I am using the USB-C to USB-C cable that came with the enclosure and I can see the Radeon logo in red inside the casing, plus the fans start spinning on the card – and when computer goes to sleep the package goes crazy with all the fans att full power. So I would say that I have power.
It is difficult to be sure however, since Gigabyte recommends a 750W PSU and the enclosure has only 650 W with max 500W GPU support
https://www.gigabyte.com/se/Graphics-Card/GV-RVEGA20-16GD-B/sp#sp
https://www.razer.com/gaming-laptops/razer-core-x
Since it is working for you, what enclosure are you using?
In the specs of my enclosure RVII is not compatible in macOS but it is compatible for Windows.
macOS Compatible Graphics Chipsets
AMD Radeon RX 580
AMD Radeon RX 570
AMD Radeon Pro WX 7100
AMD Radeon RX Vega 56
AMD Radeon RX Vega 64
AMD Vega Frontier Edition Air
AMD Radeon Pro WX 9100
AMD Radeon RX 470
AMD Radeon RX 480
Windows 10 Compatible Graphics Chipsets
Qualified NVIDIA ® GeForce ® graphics chipsets
NVIDIA ® GeForce ® RTX 2080 Ti
NVIDIA ® GeForce ® RTX 2080 Super
NVIDIA ® GeForce ® RTX 2070 Super
NVIDIA ® GeForce ® RTX 2060 Super
NVIDIA ® GeForce ® GTX Titan X
NVIDIA ® GeForce ® GTX Titan V
NVIDIA ® GeForce ® GTX Titan Xp
NVIDIA ® GeForce ® GTX 1080 Ti
NVIDIA ® GeForce ® GTX 1070 Ti
NVIDIA ® GeForce ® GTX 1060
NVIDIA ® GeForce ® GTX 1050 Ti
NVIDIA ® GeForce ® GTX 980 Ti
NVIDIA ® GeForce ® GTX 970
NVIDIA ® GeForce ® GTX 960
NVIDIA ® GeForce ® GTX 950
NVIDIA ® GeForce ® GTX 750 Ti
Qualified NVIDIA ® Quadro ® graphics chipsets
NVIDIA ® Quadro ® P4000
NVIDIA ® Quadro ® P5000
NVIDIA ® Quadro ® P6000
NVIDIA ® Quadro ® GP100
Qualified AMD Radeon™ graphics chipsets
AMD Radeon™ VII
AMD Radeon™ VEGA RX 64
AMD Radeon™ VEGA RX 56
AMD Radeon™ RX 500 Series
AMD Radeon™ RX 400 Series
AMD Radeon™ R9 Fury
AMD Radeon™ R9 Nano
AMD Radeon™ R9 300 Series
AMD Radeon™ R9 290X
AMD Radeon™ R9 290
AMD Radeon™ R9 285
