System specs (model inc screen size, CPU, iGPU, dGPU, operating system)
Laptop: Dell Precision 7530
Display: 15.6" Internal Display
CPU: Intel i9-8950HK
RAM: 4x 16 GB (DDR4-3200)
iGPU: Intel UHD 630
dGPU1: NVIDIA Quadro P3200
SSD: 3x 1TB Samsung 970 Pro m.2
Windows: 10 Pro for Workstations
Nvidia RTX 2080 Ti Founder's Edition
Akitio Node Pro
Corsair SF600 PSU
Noctua 92mm Fan
Cable Matters TB3 Cable
Mostly plug and play. I was previously using a GTX 1080 Ti in a Powercolor Devil Box. I used DDU to remove the Nvidia drivers and then reinstalled them with the new eGPU connected.
External 4K Monitor.
Time Spy (10175): https://www.3dmark.com/spy/4599695
Fire Strike Ultra (7168): https://www.3dmark.com/fs/16587667
Fire Strike (18830): https://www.3dmark.com/fs/16588023
Unigine Superposition (10372):
CUDA-Z (2571):
Madmartigan1,
Are you running this setup daily? How is its stability? Are you satisfied with the hardware?
Thanks,
Frank
.What a beast of a setup. Nice!
-Macbook Pro mid 2017 15"
-Razer Core X
-RTX 2080 (MSI Gaming X Trio)
-ROG PG279Q
2017 15" MacBook Pro (RP560) [7th,4C,H] + RTX 2080 @ 32Gbps-TB3 (Razer Core X) + Win10 [build link]
Hi, @franklesniak
I'm running pretty similar setup: https://egpu.io/forums/builds/dell-precision-7530-quadro-2000-gtx1080ti32gbps-tb3-win10-pro-xacrett/
The build is used every day and is extremely stable, except for minor driver problems at the very beginning (solved with full reinstall).
Dell Precision 7530: i9-8950k, 32Gb DDR4, Quadro 2000 internal GPU
Razer Core X: Palit GeForce 1080Ti Founders Edition
2018 15" Dell Precision 7530 (Q P2000) [8th,6C,H] + GTX 1080 Ti @ 32Gbps-TB3 (Razer Core X) + Win10 [build link]
