2018 15" MacBook Pro (RP560X) [8th,6C,H] + GTX 1080 @ 32Gbps-TB3 (AORUS Gaming B...
2018 15" MacBook Pro (RP560X) [8th,6C,H] + GTX 1080 @ 32Gbps-TB3 (AORUS Gaming Box) + macOS 10.13 & Win10 [decopastorius]
decopastorius
(@decopastorius)
Thank you for the incredible wealth of information on the site - it helped me tremendously in setting up this system with basically no real knowledge. I just finished my setup and it is working flawlessly.
System specs (model inc screen size, CPU, iGPU, dGPU, operating system)
2018 MBP / Touch Bar
15"
i9 2.90GHx
MacOS Mojave (updated)
Win 10 on Bootcamp - 1803 (just updated, already installed)
Radeon PRO560X
Aorus GaminBox
NVIDIA GTX 1080
Installation was (almost) a breeze. I took a LONG time to figure out that the very first connection between the eGPU and the computer had to be BEFORE starting Windows OS, while the following re-boots are all as explained in other posts, basically waiting for 2-3 Windows Circles to go by.
Steps (already had Bootcamp and Win 10 installed)
1 - Connect eGPU (turned ON) to Laptop via TB3
2 - Turn laptop in Win 10
3 - Use GEFORCE to install drivers
4 - Re-boot
5 - Disconnect eGPU from laptop (before Win comes in)
6 - Connect eGPU at 2-3 Windows boot-up circles
7 - Working!!!
If it wasn't from the long time it took me to try it on BEFORE turning Win 10 on for the very first install, this whole thing would have literally taken 10 minutes. Very happy
The only downside is that my BT mouse will not work if the eGPU is connected - couldn't find any solution to this or others with the same problem.
Performance Information
Memory Copy
Host Pinned to Device: 2223.37 MiB/s
Host Pageable to Device: 1738.55 MiB/s
Device to Host Pinned: 2664.39 MiB/s
Device to Host Pageable: 2247.84 MiB/s
Device to Device: 105.233 GiB/s
GPU Core Performance
Single-precision Float: 8640.92 Gflop/s
Double-precision Float: 281.187 Gflop/s
64-bit Integer: 487.098 Giop/s
32-bit Integer: 2711.6 Giop/s
24-bit Integer: 2145.64 Giop/s
This is my wife's computer. She uses Rhino 6 with Vray for rendering and it was taking a LOOOONG time do get anything done. Much, much faster now
Thanks again  for the amazing information shared by this community! I doubt i'd have been able to get this going without you
(@sam_ma)
I cant get the egpu to work, it does connect and I can see it in the Nvidia application but when Im tryning to run a game it cant be detected.
What Im missing here?
btw Im using internal display.
(@buh_khuu)
@decopastorius at which moment do you plug in the eGPU ? not for installations, but using after it. I've not been able to time my plug in. Which port works the best for you, ive been trying all the ports, but wasnt helping me.
2018 15" MacBook Pro I7-8850H RP560X
Razer Core X with Sapphire Radeon Vega 56
Dual LG 4K Monitors (27UD88 and 27UD69)
Running MacOS Catalina and Windows 1903 non optional update
ricc
 ricc
(@ricc)
Not totally sure, but i read somewhere that older DirectX games can't use eGPUs. Is your game using DX9?
2014 Macbook Pro 15" Iris Pro /w Aorus Gaming Box GTX 1070
