2019 13" Razer Blade Stealth [10th,4C,G] + RTX 2070 Super @ 32Gbps-TB3 (Razer Co...
2019 13" Razer Blade Stealth [10th,4C,G] + RTX 2070 Super @ 32Gbps-TB3 (Razer Core X) + Win10
(@gerd_fuafsljfe)
Razer Blade Stealth 13.3"
Processor: i7-1065g7
Memory: 16GB LPDDR4-3733
Graphics: Intel Iris Plus
Windows 10
Razer Core X
Gigabyte RTX 2070 Super Windforce OC 3X 8GB
Running on internal monitor for now
Hardware pictures
Maybe later
Plug, wait some time for the drivers to install automatically, and play
Aida64:
Razer aida64
Unigine Valley Extreme HD on internal screen:
Razer Valley internal
Unigine Valley Extreme HD external:
Razer Valley external
Superposition Medium/Extreme internal:
Razer Superposition medium internal
Razer Superposition internal
Superposition Medium/Extreme external:
Razer Superposition medium external
Razer Superposition external
none so far
2022 13" ASUS Flow Z13 (RTX3050Ti) [12th,14C,H] + RTX 2070 Super @ 32Gbps-TB4 (Razer Core X) + Win11 [build link]
(@gerd_fuafsljfe)
Quite confusingly the performance on the external screen isnt better than on the internal screen. Anyone got an idea why? I replicated it twice, so it does not seem to be an abnormality
Its not a real screen though but a cheap TV. The image is zoomed in a bit, but that shouldnt impact performance right?
screen image
Havnor
(@havnor)
Noticed that you have tried few notebooks with this setup and wondered which one did you end up keeping. I am planning on switching to eGPU hence would like your feedback for Razer Stealth or any other.
(@gerd_fuafsljfe)
@havnor
i collected most of my thoughts in this thread:
https://egpu.io/forums/which-gear-should-i-buy/benchmarking-different-notebooks/
The short form is: The Razer and the Lenovo S740 are very similar in terms of build quality and performance.
I decided to keep the Lenovo because its a good bit cheaper and I read some bad stories about Razer Blades breaking and Razer taking some time to fix it. The Razer is probably a bit cooler/quieter. In any case I dont think you can go wrong with either.
