Overview - eGPU driving a USB-C only monitor
The eGPU is used for 10bit 4k video production workflow (Adobe Premiere Pro, Avid, DaVinci Resolve). One challenge for this setup was to drive a monitor that ONLY has a USB-C input (the LG 5k). I got the Radeon Pro W5700, which was the only card with USB-C output that I could find (as of April 2020).  The Akitio Node Titan is well designed and is one of the few using the latest Intel Titan Ridge chipset.
2019 Mac Mini -
- 3.2 GHz 6‑core 8th‑generation Intel Core i7 (Turbo Boost up to 4.6GHz)
- 32 GB 2666MHz DDR4
Mac OS Catalina 10.15.6
27-inch LG UltraFine 5K - USB-C input at 4K
BenQÂ SW271 27 inch 4KÂ - HDMI 4K
AKiTio Node Titan
Radeon Pro W5700Â
Installation - Node Titan EGPU Enclosure
Very easy install. Just the right amount of space in the enclosure for the 2 slot Radeon Pro card. Build quality and design of the enclosure is excellent.
Details:
Unscrew the two case bolts on back. Slide off case top. Unscrew the two long PCI screws and remove the face plate since this is a 2 slot card. The Titan has two bundles of 6+2 power cables and the Radeon Pro needs a 6 pin power and an 8 pin power. Plug in one of the 6 pin bundles into the back of the Radeon Pro. Take the other power bundle and push the 6 pin next to the 2 pin. They are keyed so there is only one orientation where the 2 pin and 6 pin fit together. Once together, push them into the 8 pin power slot on the Radeon. Now carefully line up the card with the PCI slot and slowly press the card into the slots. Tighten the two long PCI screws. Put case top back on and tighten the two case bolts.
The short Thunderbolt cable goes from the Thunderbolt port on the back left of the Titan (not the Video card ports) and connects to the Mac. Â
Installation OSXÂ
10.15.6 or higher required!  When you connect the eGPU, you should see an eGPU (square circuit) icon in the OSX menu bar.
Right click on the apps you use and select "info" - then set "Prefer External EGPU" for each app you use
Installation LG 5K MonitorÂ
The USB-C port on the Radeon card is connected with a USB-C cable to the 5K monitor USB-C port. One of the Displayport ports is used to connect the second HDMI monitor at 4k, however because of the Catalina sleep problem, the second monitor also has a second connection directly to the mini so that the eGpu can be disabled and then the mini can be put to sleep.
The LG 5K has no power switch and only has USB-C (or Thunderbolt) input. The only card I could find with USB-C display output is the Radeon PRO W5700. The only way I could get the LG display to power on was to attach a second monitor (any HDMI or DisplayPort monitor) to the Node Titan. Once there is a second monitor on the Titan, it will power up the LG 5K. I don't think this is an issue with the Radeon card or the Node Titan. Note that I believe USB-C in this setup only displays 4K but it looked great. As an alternative, there are bi-directional USB-C cables, but I haven't tried those.
Benchmarks Â
No official benchmarks, but this is a game changer. I can now preview Premiere Pro effects at 4k 10bit resolution with no issues. Previously I was unable to use the internal GPU at all for many tasks and had to use software due to internal GPU memory limits. I can now use the eGPU with Davinci Resolve, Premiere Pro, and Avid with excellent performance.
Resolved IssuesÂ
- A second HDMI monitor was needed to be attached to the EGPU to force it to power on the LG 5K.
- Mojave did not see the eGPU and Catalina was required. At least 10.15.6 highly recommended!
- Adobe Premiere Pro 14.1 has known problems using any GPU with legacy titles - down-revving Premiere to 14.0.4 resolved this.
- The system hangs if it goes to sleep with the eGPU attached.  Apparently this is a known issue with 10.15.4. This is fixed in 10.15.6
Open Issues
- None
Photos
@corb555, I am thinking of getting this card and switching out my VII, I would be very happy if you could do some benchmarks.
Â
Mac Pro 6,1. (2013). 12-Core 2.7GHz 128GB RAM 1TB SSD, Razer Core X Chroma with Radeon VII 16GB
@cameron_coombs, What benchmarks are you specifically interested in?
Â
@corb555, hi,
related the open issue
 1.The system hangs if it goes to sleep with the eGPU attached.  Apparently this is a known issue with 10.15.4
Do you know if this is specific to this eGPU or it can happen also with a different one, for example, a Razer Core X?
I'm asking this because I see some posts from 2017 with an eGPU from the same manufacturer with the same/similar problem.
Thanks.
Â
.@pop_gheorghe, I've seen reports of this problem with people using Akitio, Sonnet, Razer core X, Mantiz Venus, and HP eGPU enclosures: eGPU sleep problems. It doesn't seem related to the enclosure type and apparently worked at some point before 10.15.4
Â
@corb555, Honestly it's tough to know what would be the best one to do. I run autodesk flame and trying to find the best card for it. Geekbench 5 might a be a good one and heaven bench.
Â
Can you please share a screenshot of the "Performance" tab from CL!ng?
