To fully test the RTX 2080 Ti Gaming Box, I needed a capable 4K G-Sync monitor. While my FreeSync 2 monitors are considered G-Sync compatible, I wanted to see if there's a difference in smoothness during gameplay. The Acer Predator XB3 (XB273K Pbmiphzx) 4K 144Hz G-Sync monitor is an excellent candidate and was on sale for $850 at the local Micro Center. It's a bulky monitor due to a cooling fan and blinders. Last component of this setup is the late 2019 Razer Blade Stealth. The best configuration for eGPU users is iGPU-only with the i7-1065G7 CPU set to 25W from the factory [$999 deal link].
System specs:
Late 2019 Razer Blade Stealth – i7-1065G7/Iris Plus Graphics iGPU/16GB RAM/256GB SSD
eGPU hardware:
AORUS Gaming Box + RTX 2080 Ti + .5m Thunderbolt 3 cable + Acer Predator XB3
Hardware pictures:
Installation steps:
There's not much in terms of installation process. Other than removing the monitor stand to access the VESA mount, everything else was plug-and-play. The late 2019 Razer Blade Stealth is an excellent ultrabook. Razer has made some refinements to to make external graphics experience more seamless. The first change is Thunderbolt Security set to no approval, Thunderbolt devices will be automatically connected similar to Mac systems. There's also Large Memory allocation in the Device Manager. This laptop also has NVM firmware version 72.0, the newest one I've seen.
I manually installed the latest Nvidia drivers. I also installed AORUS Engine and RGB Fusion to control the RTX 2080 Ti eGPU and lighting mode. It's possible to use this eGPU with the Razer Blade Stealth in internal display mode but that would limit the RTX 2080 Ti capabilities.
AIDA64 confirmed the performance advantages Ice Lake provides for eGPU applications. Prior to this CPU, Nvidia eGPU through Thunderbolt 3 connection cannot reach higher than 2,2XX MB/s for H2D. There are two "Integrated Thunderbolt PCI Express" roots. Each can host two Thunderbolt 3 ports. Razer only made use of one in this Blade Stealth for a single TB3 port on the right side.
Benchmarks:
Razer marketed the 2019 Blade Stealth as a gaming ultrabook*. The asterisk denotes it needs an eGPU to do so. 😀
Internal Display Mode | FHD External Monitor | QHD External Monitor | UHD External Monitor |
Comments:
I will be installing a larger NVMe drive on this Razer Blade Stealth to download games then run more benchmarks. First impression from these results is that we can expect gameplay at 144Hz FHD, 120Hz QHD, and 60Hz UHD.
I believe Acer displays have a "show framerate" option to prove that gsync is working? In macOS the framerate is constant. Does it fluctuate in Windows during game play? Is it constant when not playing games?
@joevt Yes, you are right. You may be able to see the yellow number in the top right corner of the screen in one of my hardware pictures. This number stays constant in Desktop and fluctuates during gameplay.
I see it now, looks like it says "122" which is in the range of your benchmarks. That's very good for Thunderbolt eGPU.
I have been running the RTX 2080 Ti Gaming Box through this 2019 Razer Blade Stealth vs 2019 13-in MacBook Pro to better understand Ice Lake TB3 performance vs older 8th gen CPU. One thing I noticed is that the RBS' i7-1065G7 CPU TDP seems to be limited at 15W when the eGPU was connected. Therefore the eGPU performance through the MacBook Pro's i7-8569U CPU can be better in some scenario. The crucial piece is not only cooling system but also thermal management profile in the firmware.
Here are Unigine and 3DMark numbers to compare with the ones in OP.
@itsage, so you're seeing about 11% faster performance at 1080p with the 13" MBPro 8th gen CPU vs RBS with 10th gen CPU?
I've been considering selling my 13" MBPro 8th gen for a new 13" HP Spectre with 10th gen cpu... Maybe 10th gen isn't much of a benefit for eGPUs??
2012 Mac mini 2.6GHz 4C i7, dual boot 10.13+1080Ti & 10.14+Vega 56 eGPU
2009 Mac Pro 5,1 6-core Xeon 3.46GHz + MSI HD7970 OC
2012 Mac Mini [3rd,4C,Q] + RX Vega 56 @ 10Gbps-TB1>TB3 (AKiTiO Node) + macOS 10.14.6 [build link]
@cnon297, It's not that clear-cut through those synthetic benchmarks. The i7-1065G7 and its direct Thunderbolt 3 connection can perform better but it seems the manufacturer has to fine-tune the laptop's firmware to make the most of eGPU. I spent the afternoon installing RTX & DLSS games to try. It's actually a great experience playing at 4K. Here's a one minute Battlefield V gameplay video for reference. It's very smooth and consistently average around 60 FPS.
Here are the settings for the 3 ray-tracing games I have.
Above 60 fps average at 4K is super impressive, especially with ray tracing in modern games... 😉
Agreed! 4K60 over TB3 is very impressive! Aorus really delivered with this new 2080Ti Gaming Box! It's a bit out of reach for me. But compared to other 2080Ti + eGPU combinations you're getting more for your money (IMO).
@itsage, did you notice any performance issues when using ethernet or USB3? How do you like the liquid cooling, any pump whine or loud fan noise? The removable air filters are a nice touch also.
@cnon297, I actually installed all the games onto the external Samsung T5 USB-C drive. It connects to the Razer Blade Stealth through the USB-C port on the left side. Ethernet port has been connected in the past week and it works very reliable at 1Gbps (no drivers needed in Windows). The Intel WiFi card in this laptop is finicky however but that's none of the eGPU enclosure's fault.
The liquid cooling system works incredibly well. The only issue I encountered was my fault; dislodged cooling fan connecter when I took the eGPU apart. I used it in different games for over four hours yesterday and the temps never reached above mid 60 degrees Celsius. I can hear the pump noise and air flow through the radiator. It's not as quiet as I'd like but very typical for an AIO liquid cooling system.
