2020 13" Razer Blade Stealth (GTX1650Ti) [10th,4C,G] + RTX 3060 Ti @ 32Gbps-TB3 ...
2020 13" Razer Blade Stealth (GTX1650Ti) [10th,4C,G] + RTX 3060 Ti @ 32Gbps-TB3 (AKiTiO Node) + Win10
mbliss11
(@mbliss11)
Laptop specs
  • Razer Stealth 2020
  • Intel Core i7-1065G7
  • 16GB Ram
  • Intel Iris Plus and 1650ti maxQ
  • 1 X TB3 (32 GBps, a.k.a. 4 lanes) + 1 USB-C 3.1 + 2 USB A
    • One is connected to eGPU (Akitio Node)
    • One is connected to power adapter
  • LG 29 inch 2560x1080P Monitor and laptop display
  • 512 GB NVME SSD
  • Windows 10 Home
eGPU hardware:
Installation steps:
Plug and play install initially.  Ran DDU in safemode and then installed driver package after reboot.  Is rock solid did not have to adjust any driver settings for stability like I did with my 2060 Super.  The 3060ti is wonderful!  Crazy fast and silent on load with absolutely no coil whine.  Idles at 32C in the enclosure.  Was fortunate enough to snag this when it was released and will be returning the 2060 Super since I paid more for it than the 3060TI!
Benchmarks:
Timespy
FireStrike Normal
FireStrike
Superposition
Superposition Extreme
Aida64
Performance difference between 3060ti and 2060 Super:
https://egpu.io/forums/builds/razer-stealth-2020-1065g7-akitio-node-rtx-2060-super/
2020 13" Razer Blade Stealth (GTX1650Ti) [10th,4C,G] + RTX 3060 Ti @ 32Gbps-TB3 (AKiTiO Node) + Win10 [build link]
itsage and nando4 liked
@mbliss11, Thank you for sharing this build! I think the RTX 3060 Ti is the best performance value atm for eGPU users. Love the look of Nvidia Founders Edition cards too.
스타채
(@kks)
I ordered the Mantiz Saturn Pro II today and ordered the GIGABYTE RTX3060Ti together. Are your scores using eGPUs achieved as much as your original purpose?
mbliss11
(@mbliss11)
@kks, I am very pleased with the results thus far!  Certainly I would be getting more FPS from a desktop and have been flirting with the idea of building an ITX box instead of the laptop but I really like having the ability to just pick up the Stealth and throw it into a bag and only have one system.  Right now I am not really going anywhere (working from home and trying to social distance as much as possible) but hopefully I"ll be able to do that more in the future.
스타채
(@kks)
@mbliss11, Glad you were satisfied. I'm also looking forward to my upcoming system. On the one hand, reading your writings gave me peace of mind too.
