2021 13" Razer Book 13 [11th,4C,G] + Radeon Pro VII @ 32Gbps-TB4 (AKiTiO Node Ti...
2021 13" Razer Book 13 [11th,4C,G] + Radeon Pro VII @ 32Gbps-TB4 (AKiTiO Node Titan) + Linux Fedora 33
Chris Hubick
(@chris_hubick)
2021 Razer Book 13 (Iris Xe)
i7-1165G7 CPU, 16GB RAM
Upgraded SSD to 1TB Samsung 980 Pro
Fedora 33 (Gnome+Wayland)
Gigabyte G32QC 32" 2560x1440 monitor.
AKiTiO Node Titan
AMD Radeon Pro VII
Replaced enclosure fan with Noctua NF-A9 FLX.
Hardware pictures
Don't have permission to attach yet.
I plugged in the eGPU and the display attached to it lit up and worked out of the box on Fedora 33.
I log in using the Gnome Classic UI, which, unbeknownst to me reverted to X.org by default, and closing my laptop lid had performance issues until I switched it back to Wayland.
My eGPU was not automatically set as primary for the system until I added a udev rule.
The Phoronix Test Suite runs, and unigine-heaven reports 30-60fps at 1440p, but I haven't yet determined if it's actually using the eGPU.
Suspend and resume works!
Although Gnome+Wayland is usable, it feels annoyingly laggy with the eGPU (unlike when using the integrated Iris Xe). I can't say for certain- it could be a delay just due to Thunderbolt, but it feels more like Linux could be copying the whole screen from main memory to the GPU whenever I switch browser tabs kinda thing- like something either isn't optimized well or doing the right thing. It feels like the Unigine game rendered better than the desktop (perhaps rendering all textures from vram on the eGPU the whole time). I'm using the external display connected to the eGPU with the laptop lid closed, and indications are that the eGPU is in use...
`journalctl | grep 'gnome-shell' | grep 'primary'` says `gnome-shell: GPU /dev/dri/card1 selected primary given udev rule`
`glxinfo` says `OpenGL renderer string: AMD VEGA20`
Chrome's `chrome://gpu/` page lists both the Intel and Radeon GPUs and says `VENDOR= 0x1002, DEVICE=0x66a1 *ACTIVE*` (the Radeon).
More debugging will be required.
Anyhow, the basic hardware seems to be operating and compatible at least.
2021 13" Razer Book 13 [11th,4C,G] + Radeon Pro VII @ 32Gbps-TB4 (AKiTiO Node Titan) + Linux Fedora 33 [build link]
@chris_hubick, Thank you for sharing this nice build! Does your Radeon VII fans go to sleep when you put the laptop to sleep? This was an issue many people experienced when pair their eGPU enclosure with the Radeon VII (firmware issue).
Chris Hubick
(@chris_hubick)
Posted by: @itsage
I just verified that, yes, the blower fan on the card comes to a stop when the system is suspended.
I haven't paid much attention, as I have the eGPU box buried at the back of my desk behind my monitor, but I thought I may still have heard intermittent fan noise from the enclosure- it's like everything goes to sleep initially but then the case fan spins up for 30 seconds or something every five minutes, or something. The only time I'm sitting there while it's suspended is when I'm playing xbox, but I'll have to quit CoD and climb back there next time and figure out if it's the card or case or power supply fan or what (can't extended suspend, gotta work right now) 😀
@chris_hubick, That's nice to hear the Radeon VII fans go to sleep. The enclosure fan and/or PSU fan can come one during sleep to keep airflow going due to Power Delivery from device to host.
Chris Hubick
(@chris_hubick)
Posted by: @itsage
Ahh, well, that explains that! AMD sure has some longstanding firmware bugs. Another common one being the PCI "reset bug" that keeps the card from reinitializing if you want to pass it through to a virtual machine using VFIO- though I hear that's also fixed now in RDNA 2 / 6000 series cards (haven't tested my Pro VII).
