2019 16" MacBook Pro (RP5600M) [9th,8C,H] + RTX 3090 @ 32Gbps-TB3 (Mantiz Saturn...
2019 16" MacBook Pro (RP5600M) [9th,8C,H] + RTX 3090 @ 32Gbps-TB3 (Mantiz Saturn Pro) + Win10 [bmagnien]
bmagnien
(@bmagnien)
Apple MacBook Pro 16”
  • i9 9980HK 8 core 2.4 Ghz @ 3.5ghz
  • 32 GB 2666MHz DDR4 memory
  • 1TB NVME SSD
  • AMD 5600m dGPU, 8GB HBM2 memory
  • LaCie 2TB Rugged SSD Pro TB3 External
  • Apple TB3 Pro Cable (2m)
  • Razer Blackwidow TE Chroma v2 TKL, Orange Switches
  • Razer Deathadder v2
  • Bootcamp Windows 10 Pro, 1903
Acer Predator X35
35” 3440x1440 180hz DisplayHDR1000 Curved Ultrawide
EVGA RTX 3090 FTW3 Ultra
24GB GDDR6X memory, OC vBios, Triple fan cooler, 3x8pin
Mantiz Saturn Pro II eGPU enclosure
Modifications:
  • Top-mounted 120mm x15mm exhaust fan (Noctua NF-A12x15 PWM chromax.black.swap)
  • Side-mounted 120mm x 25mm intake fan (Noctua NF-F12 iPPC-2000)
  • Reversed PSU to intake off GPU backplate
  • 1TB Samsung EVO 860 2.5” SATA SSD
Hardware pictures
Top-mounted exhaust fan installed by having a local metal shop drill a circular cutout and 4 pass-through screw holes sized to match the steel mesh grill and case fan screws. Fan grills are used internally on the top exhaust and side intake to prevent wires from catching fan from the interior. PSU intake does not use an internal fan grill as it's nearly touching the backplate of the GPU with no risk of wire interference, and wanted maximum airflow there as it's the hottest part of the unit. Initial top-mounted exhaust fan sizing test was done with a standard Noctua 120x15 (pictured), which I replaced with a chromax black as you could see the white through the black steel grill. Also the side fan pictured here is the original Mantiz side fan, I've since replaced it with the Noctua NF-F12 listed above. Both Noctuas run off a single PWM-controlled header on the RTX 3090, and are individually controlled along with the 3 GPU shroud fans via EVGA Precision X1. GPU temps max around 66c at 100% fans, which is LOUD but I needed the extra cooling to push OCs for stability in these benchmarks. I run at auto fan curve while gaming with a more reasonable OC and the setup is quieter than the fans on my MBP
3
7
6
4
8
5
9
  1. Boot into Bootcamp, allow complete startup to desktop
  2. Plug TB3 cable into right side MBP (already connected to eGPU)
  3. Have all peripherals plugged into eGPU (mouse, keyboard, laptop cooler) and DP cable out of GPU directly connected to powered-on external monitor
  4. [Optional] LaCie TB3 external SSD plugged into left side MBP (confirmed full speed ~ 1500mbs write, 2500mbs read while eGPU running)
  5. SATA eGPU SSD disabled in Windows (only used as backup device when I use the eGPU as a glorified dock in OSX, split into two partitions for Time Machine and WinClone Bootcamp backup) so SATA doesn't take any bandwidth away from eGPU in Bootcamp
  6. Turn on eGPU
  7. All peripherals power on and become usable
  8. Manually download and install latest Nvidia drivers (not via Nvidia Experience) as I have all automatic Windows Updates/Driver downloads disabled
  9. No need to uninstall AMD drivers or disable dGPU
  10. Works like a charm
  11. To turn off: Select 'Shutdown' - after MBP shuts down, turn off eGPU.
  12. Boot back up and either log into OSX or repeat steps 1,2,3,6 above
There will be no data on internal monitor performance as I have no interest in utilizing this eGPU in that manner.
CUDA-Z: Host to Device: 2259.5MiB/s
CUDA Z 3090
Synthetic Benchmarks
3DMark:
Port Royal
(eGPU 3090) / (avg. Desktop 3090*)
Score: 10569 / 13265*
eGPU % Difference: -20%
Mem Offset: 1200
Core Offset: 85
PortRoyal
TimeSpy
Graphics Score: 17886 / 19592*
eGPU % Difference: -9%
Mem Offset: 800
Core Offset: 55
TS
TimeSpy Extreme
Graphics Score: 10202 / 10182*
eGPU % Difference: +<1%
Mem Offset: 1200
Core Offset: 85
TSE
Fire Strike Extreme
Graphics Score: 17209 / 24095*
eGPU % Difference: -29%
Total Score: 15850 / 21423*
eGPU % Difference: -26%
Mem Offset: 1200
Core Offset: 75
FSE
Fire Strike Ultra
Graphics Score: 10280 / 12492*
eGPU % Difference: -18%
Total Score: 10426 / 12489*
eGPU % Difference: -16%
Mem Offset: 1200
Core Offset: 75
FSU
3DMark Comparables: 3dmark.com/search
SuperPosition:
1080p Extreme
(eGPU 3090) / (avg. Desktop 3090**)
Score: 12468 / 12452**
SP 1080pExt
4k Optimized
Score: 16464 / 16597**
eGPU % Difference: -<1%
SP 4kOpt
8k Optimized
Score: 7645 / 7285**
eGPU % Difference: +5%
SP 8kOpt
**Superposition Comparables: https://www.overclock3d.net/reviews/gpu_displays/msi_rtx_3090_gaming_x_trio_review/19
Gaming Benchmarks:
For all games:
  • OC vBios on with additional +55 core offset &, +800 memory offset overclock (except for Metro High, Ultra, Extreme, and RTX presets which were only stable at +40/+600)
  • Vsync off
  • Gsync off
  • Full screen
  • 3440x1440
  • HDR1000, 10-bit color depth, full RGB
  • 144hz
  • Built-in benchmarks
  • Built-in named quality presets (except RDR2 as presets are broken, 2 custom combos below)
  • Average benchmark FPS listed, more details in screenshots
Shadow of the Tomb Raider
  • Highest Preset, DLSS On, RTX Off: 78
    Shadow HighestPreset DLSS RTX OFF
  • Highest Preset, DLSS On, RTX Medium: 76
    Shadow HighestPreset DLSS RTX MED
  • Highest Preset, DLSS On, RTX High: 60
    Shadow HighestPreset DLSS RTX HIGH
  • Highest Preset, DLSS On, RTX Ultra: 59
    Shadow HighestPreset DLSS RTX Ultra
Metro Exodus
  • Low: 121
    Metro Low
  • Normal: 83
    Metro Normal
  • High: 67
    Metro High
  • Ultra: 53
    Metro Ultra
  • Extreme: 37
    Metro Extreme
  • RTX: 49
    Metro RTX
Forza Horizon 4
  • Very Low: 149
    ForzaVeryLow
  • Low: 127
    ForzaLow
  • Medium: 111
    ForzaMedium
  • High: 108
    ForzaHigh
  • Ultra: 93
    ForzaUltra
  • Every Setting Maxed: 76
    ForzaEverythingMax
Horizon Zero Dawn
  • Favor Performance: 79
    Horizon FavorPerformance
  • Favor Quality: 65
    Horizon FavorQuality
  • Ultimate Quality: 61
    Horizon UltimateQuality
Far Cry 5
  • Low: 117
    FC5 Low
  • Normal: 107
    FC5 Normal
  • High: 101
    FC5 High
  • Ultra: 94
    FC5 Ultra
Red Dead Redemption 2
Texture Quality Ultra, AF x16, MSAA Off, On/Off settings set to Off, Level of detail sliders set to midpoint
  • Quality settings set to High: 60
    RDR2 High
  • Quality settings set to Medium: 66
    RDR2 Medium
Additional Benchmark Comparisons (3080 vs 3090 vs Desktop vs eGPU):
Time Spy (1440p) Graphics Score
GPU
All Desktop (Average)
9980HK MBP w/eGPU
% Difference
GTX 980
4,365
4,154
-5%
GTX 1080
7,571
6,824
-9%
RTX 2080
11,116
9251
-17%
RTX 3080
17,551
15,234*
-13%*
RTX 3090**
19,710
17,886**
-9%
 *Intel Core i5-1035G7 Processor
**EVGA 3090 FTW3 Ultra
Time Spy Extreme (4K) Graphics Score
GPU
eGPU Sample (Best)
% Difference
RTX 3080
8,861
8,234
-7%
RTX 3090
10,185
10,202*
+<1%
*Intel Core i9-9980HK Processor, EVGA 3090 FTW3 Ultra
Port Royal (Ray Tracing)
GPU
eGPU Sample (Best)
% Difference
RTX 3080
11,380
8,873
-22%
RTX 3090
13,248
10,569*
-20%
Firestrike Extreme (1440p) Graphics Score
GPU
eGPU Sample (Best)
% Difference
RTX 3080
20,966
15,213
-28%
RTX 3090
23,856
17,209*
-28%
Firestrike Ultra (4K) Graphics Score
GPU
eGPU Sample (Best)
% Difference
RTX 3080
10,775
9,496
-12%
RTX 3090
12,501
10,280*
-18%
Super Position (1080P Extreme)
GPU
Desktop Sample
eGPU Sample
% Difference
RTX 3080
10,722
10,389
-5%
RTX 3090
12,452**
12,468*
+<1%
**  https://www.overclock3d.net/reviews/gpu_displays/msi_rtx_3090_gaming_x_trio_review/19
Super Position (4k Optimized)
GPU
Desktop Sample
eGPU Sample
% Difference
RTX 3080
14,226
13, 391
-6%
RTX 3090
16,597**
16,464*
-<1%
Super Position (8k Optimized)
GPU
Desktop Sample
eGPU Sample
% Difference
RTX 3080
6453
--No-Data--
-N/A-
RTX 3090
7,285**
7,645*
+5%
2019 16" MacBook Pro (RP5600M) [9th,8C,H] + RTX 3090 @ 32Gbps-TB3 (Mantiz Saturn Pro) + Win10 [build link]
nQ4c, Mini i5, itsage and 1 people liked
@bmagnien, Thank you for taking the time to build and share results of your Mantiz Saturn Pro + EVGA RTX 3090 FTW3 Ultra eGPU setup. This should clear up doubts on Thunderbolt 3 bottlenecking high power GPUs. I wonder if the RTX 3090 FE cooling system is overwhelming the Desktop cooling in some of the comparable results. Your modifications to the Mantiz Saturn Pro definitely improved cooling for the graphics card too.
bmagnien liked
@bmagnien, thanks for sharing this build! Quick note about memory overclocks though - 3080/3090 have ECC so increasing clocks too much might actually cause performance loss - on non-ECC memory we would see the typical glitchy artifacting the display but with ECC it tries to correct and there is an FPS penalty.
bmagnien
(@bmagnien)
@mac_editor, all of the clocks listed were arrived at by starting at stock and ramping up until performance stopped increasing or the application became unstable. They were calculated per application. Would you recommend I handle it differently or test another way?
@bmagnien, sounds like you did due diligence while overclocking so everything is probably ok, but some of your offsets seemed unusually high (+1200 mem) to me. Clearly it isn't a stable overclock (which you do mention). Generally, baseline configuration performance numbers interest me more as that's how a typical user would be using their eGPU (but then I suppose typical users aren't purchasing the 3090 :p). Nonetheless, really appreciate your work in highlighting 3090 performance over eGPU! 4k60 gaming is a really good usage scenario for eGPUs in most cases and the 30 series seems to fit the bill well.
bmagnien liked
bmagnien
(@bmagnien)
Update 1 (9/28/2020, 7:21pm EST): Added the following to the end of the original post for context:
OliverB
(@oliverb)
Thank you for this most interesting build!
Is it safe to assume that the EVGA  RTX 3090  FTW3 Ultra is one of the fasted GPUs available?
Do you see any catch like noise, heat, size or power consumption?
I assume 300 Watt supply (Asus XG Station Pro) is not enough, is it?!
bmagnien
(@bmagnien)
@oliverb, you’re welcome! The evga FTW3 is a more than capable card, up there with the best for stock performance. If you’re planning on OCing, it’ll come down more to silicon lottery than to differences in AIB. Right now evga is struggling with a working version of their 500w xoc bios while other AIBs like the Asus Strix and MSI GAMING x trio are doing well at 500w+. And all would most likely perform even better with additional liquid cooling either via an AIO or custom loop, but those probably aren’t options available in an eGPU. I found the thermals for the FTW3 worked particularly well in this eGPU setup due to the vertical fin stack of the heat sink causing hot air to be expelled from the top and up and out via the installed roof exhaust
Limga
(@limga)
@bmagnien, thank you for sharing your build. I am having MBP 16 with 5500M and I am thinking a lot of getting an eGPU for gaming. Can you please confirm that all peripherals are working well with Windows 10 Boot Camp on MBP 16? I am considering Mantiz Saturn Pro and I would like to use it's SD-card slot and gigabit Ethernet, but I have read that there could be some problems on Windows 10 Boot Camp. Thank you!
MacBook Pro 16 (5500M 8Gb, i9 2.3GHz, 32Gb RAM), Razer Core X Chroma, Vega 64 (custom liquid cooling)
Charly4 liked
kurinzo
(@kurinzo)
Mu results with Inno3d 3090 on same configuration are much worse, dont know why. 14979 on 4k optimized in Superposition. Any suggestions?
