2021 14" Lenovo Yoga Slim 7i Pro (MX450) [11th,4C,H] + GTX 1080 @ 32Gbps-TB4 (Wi...
2021 14" Lenovo Yoga Slim 7i Pro (MX450) [11th,4C,H] + GTX 1080 @ 32Gbps-TB4 (Wikingoo eGPU) + Win10 21H1 // Custom Loop Water Cooled eGPU
Boltoway
(@boltoway)
Reputable Member Moderator
Laptop Specifications
- 14.0" 16:10 (2240x1400) IPS Display
- 11th Gen Intel Core i7-11370H
- Intel Iris Xe iGPU
- Nvidia MX450 dGPU (25W / GDDR6)
- 16GB Soldered LPDDR4x-4266 RAM
- 1TB Samsung 980 M.2 NVMe SSD
- Intel Wi-Fi 6 AX201 11ax, 2x2 + Bluetooth 5.1
Software
- Microsoft Windows 10 Enterprise 21H1 Build 19043
Hardware
Lenovo ThinkPad Universal Thunderbolt 4 Dock
- Acer Predator
 XB253Q 24.5 FHD 144Hz IPS G-Sync Monitor
- Logitech G512 Carbon Mechanical Keyboard
- Logitech G603 Wireless Mouse
- M-Audio Air 192/4 USB Audio Interface
- PreSonus Eris 3.5 Active Studio Monitors
- Presonus Eris Sub8 Active Studio Subwoofer
- BeyerDynamic DT770 Pro 250Ω Headphones
- M-Audio Nova XLR Microphone
eGPU Hardware
Custom Watercooled Wikingoo eGPU + Gigabyte GTX 1080 Mini ITX 8G + SilverStone 500W 80+ Gold Modular SFX PSU + Plugable 1M Thunderbolt 4 Cable
Hardware Images
The eGPU mount is made from some generic hardware brackets and my ThinkPad Dock is mounted with double sided tape:
PXL 20211213 231921589
Building the Watercooled eGPU
Building the waterloop for the eGPU was surprisingly simple and required very little modification and no specialised tools. You can find a more detailed forum post here.
PXL 20211213 222740255
PXL 20211213 222806037
Installation
Installation was very simple: Plug in the  Wikingoo eGPU  with it already powered on and wait until Windows has installed device drivers > install latest Nvidia graphics drivers > Done.
It can be hot plugged, cold plugged, will display the Windows login screen, support Windows sleep-states and can even display my system BIOS from either a cold startup or system restart. The later of these was something that my   Aorus Gaming Box   1080 could not do. Furthermore, it works exceptionally well while being daisy-chained through a Thunderbolt 4 dock.
I added a TdrDelay ValueData of 10 and a TdrDdiDelay ValueData of 20 in the Windows Registry Editor to allow Windows a longer 'timeout' period for the GPU to respond. It has fixed many crashes and BSOD errors in previous   builds  , with no downside whatsoever.
I changed the Nvidia Power Management Mode to 'Prefer Maximum Performance'.
I further modified the Windows Registry to add Link State Power Management into my Windows Power Settings.
Steps to do these can be found here
Cuda-Z  Bandwidth:
Cuda Z Bandwidth Crop
CineBench R23 Single and Multicore:
Cinebench 1559 CROP
Cinebench 6634 CROP
Unigine Heaven Intel Iris iGPU:
Heaven Iris 486
Unigine Heaven Nvidia MX450 dGPU:
Heaven MX450 624
Unigine Heaven Nvidia GTX 1080 eGPU:
Unigine Heaven 2640 Crop
3DMark TimeSpy:
TimeSpy 6982 Crop
GPU Overclocking and Thermal Performance:
I used a Gigabyte  GTX 1080  Mini from an  Aorus Gaming Box  1080 and a Bykski Waterblock. Originally, the GTX 1080 would peak at around ~72C. In the loop with a +196Mhz Core Overclock and +503Mhz Memory Overclock, the GTX 1080 never goes above 55C with the fans and pump set to only 50%.
Temperature Crop
Steam Achievment
Compared to the original Gaming Box 1080, my Unigine Heaven and 3DMark TimeSpy Score both increased by ~9.7%.
Heaven 1080 2406
3DMark TimeSpy 1080 6477
A detailed review of the  Wikingoo eGPU  can be found here.
A detailed forum post regarding the DIY watercooled eGPU can be found here.
TH3P4 Thunderbolt GPU Dock Review
TH3P4G2 Thunderbolt GPU Dock Review
Wikingoo Thunderbolt GPU Dock Review
DIY Portable Custom Water Cooled Thunderbolt 3 eGPU
Thunderbolt 4 Docks, eGPU Daisy Chaining and the One-Cable Dream
Windows 10 Solutions for eGPU BSOD, Crashing, System Freezing and Stuttering
Adding Advanced Power Management Options to Windows Laptops for Performance, Thermal Throttling & Power Management
2021 14" Lenovo Yoga Slim 7i Pro (MX450) [11th,4C,H] + GTX 1080 @ 32Gbps-TB4 (Wikingoo eGPU) + Win10 21H1 // Custom Loop Water Cooled eGPU [build link]
ARN, mr.ribeiro, TungLong201 and 2 people liked
ARN
 ARN
(@arn)
Very nice and clean upper aesthetics, I didn't knew there were 1080s that small.
Time is worth what we do with it.
-No GPUs were harmed during the making of my build-
2017 13" HP Spectre 13 [7th,2C,U] + RTX 3060 @ 16Gbps-TB3 (JEYI Thunderdock * ADT-Link R43SG) + Win10 // custom 3D printed case [build link]
Boltoway liked
mr.ribeiro
(@mr-ribeiro)
@boltoway, I am seeing your build just now, but is awesome, i liked your build looks so clean Smile
2016 15" ASUS ZenBook Pro UX501VW (GTX960M) [6th,4C,H] + RTX 2070 @ 32Gbps-TB3 (Orico TOM2T3-G40 * ADT-Link R43SL) + Win10 [build link]
Boltoway liked
Boltoway
(@boltoway)
nando4 and mr.ribeiro liked
@boltoway, looking forward to your Dell XPS 15 9510 build.
Also eager to see Dell's 12th-gen refresh of that laptop with higher MP webcam sometime soon.
Boltoway liked
Boltoway
(@boltoway)
@nando4
I was tossing up between the XPS 15 and ThinkPad X1 Extreme Gen 4. I'm very happy with it so far and look forward to updating my build.
I'm also keen to see what they do with 12th Gen and how well it works with eGPUs, although I am the opposite about the webcam as it is basically the last hardware specification I care for on a device haha.
DXPHeGPUio
(@dxphegpuio)
@boltoway, Can't speak for the Dell but not particularly impressed by the X1E4 because it's very locked down- there's no undervolting because the workaround is locked out and the override for the power limit throttling also doesn't work so what you get is what you get. Thinking of moving on to a proper thin and light gaming laptop when I upgrade from my X1E2 tbh so I don't care for the XPS either.
2019 15" Lenovo ThinkPad X1 Extreme Gen 2 (GTX1650) [9th,8C,H] + GTX 1080 Ti @ 32Gbps-TB3 (Razer Core X Chroma) + Win10 21H2 [build link]
Boltoway
(@boltoway)
@dxphegpuio
There were mixed reviews for the X1EG4.
So far the 9510 has been really good. It is basically silent when running through the eGPU and not using the RTX 3050 Ti. Dell has tuned the thermals a lot more than previous XPS series so it doesn't get nearly as hot under the initial turbo boost like the old models did.
Take a look at the Intel NUC X15 laptop. It was another one of my options but it didn't have two Thunderbolt ports so I decided for the XPS. It can be purchased as a bare-bones kit or branded as the Eluktronics MAG-15R / XPG Xenia 15. It is very well reviewed and probably the cleanest gaming laptop available alongside the Razer Blade
DXPHeGPUio
(@dxphegpuio)
@boltoway, X15 looks alright at first glance and the price is right if and only if I reuse my old components- much cheaper than the MSI GS66 and Zephyrus M16. Thanks, will keep an eye on how their Alder/Raptor Lake iterations turn out as I already missed the boat on Tiger Lake with the 3070 M16 which was discontinued partway through.
Boltoway liked
wildfear
(@wildfear)
@boltoway
Got my 9510 for few weeks, looking forward to compare with my setup.
I will post my build when I got some time !
2022 16" ASUS Zephyrus M16 (RTX3070Ti) [12th,14C,H] + RTX 3080 @ 32Gbps-TB4 (WD_Black D50 * ADT-Link R43SG) + Win11 // inc MSI GS66 12700h numbers as bonus [build link]
Boltoway and nando4 liked
