2021 14" Lenovo Yoga Slim 7i Pro (MX450) [11th,4C,H] + RTX 3060 @ 32Gbps-TB4 (AO...
2021 14" Lenovo Yoga Slim 7i Pro (MX450) [11th,4C,H] + RTX 3060 @ 32Gbps-TB4 (AORUS Gaming Box) + Win10 21H1
Boltoway
(@boltoway)
Reputable Member Moderator
20210813 165848
After being extremely happy with the performance and stability of my Lenovo Thinkpad E14 Gen 2 eGPU System, I decided to upgrade to a slightly higher performance laptop: the Lenovo Yoga Slim 7i Pro. This laptop has some interesting features for a 14" Ultrabook. It has great all-metal build quality, offers extraordinary performance for such a small device, and is by far the best eGPU oriented ultrabook I have ever used.
Laptop Specifications
- 14.0" 16:10 (2240x1400) IPS Display
- 11th Gen Intel Core i7-11370H
- Intel Iris Xe iGPU
- Nvidia MX450 dGPU (25W / GDDR6)
- 16GB Soldered LPDDR4x-4266 RAM
- 1TB Samsung 980 M.2 NVMe SSD
- Intel Wi-Fi 6 AX201 11ax, 2x2 + Bluetooth 5.1
Software
- Microsoft Windows 10 Enterprise 21H1 Build 19043
Hardware
- Acer Predator XB253Q 24.5 FHD 144Hz IPS G-Sync Monitor
- Logitech G512 Carbon Mechanical Keyboard
- Logitech G603 Wireless Mouse
- M-Audio Air 192/4 USB Audio Interface
- PreSonus Eris 4.5 Active Studio Monitors
- Presonus Eris Sub8 Active Studio Subwoofer
- BeyerDynamic DT770 Pro 250Ω Headphones
- M-Audio Nova XLR Microphone
eGPU Hardware
AORUS Gaming Box + Asus GeForce RTX 3060 Dual OC Edition + Plugable 80CM Thunderbolt 3 Cable
Hardware Images
I made the desk from a Karri hardwood panel and prefabricated steel legs:
20210813 165834
20210813 165859
The eGPU bracket is made from an offcut of the desk and some generic brackets. The power-only USB port on the Aorus Gaming Box runs a 120mm fan that provides additional airflow to the eGPU:
20210813 165918
20210331 120920
I swapped out the GTX 1080 for an Asus GeForce RTX 3060 Dual OC. Absolutely no modification was required for the RTX 3060 to work exactly as the original Aorus Gaming Box 1080. It fit perfectly:
20210813 083718 2mp
20210813 083732
20210813 083739
I recently purchased an audio-interface to use with the eGPU. It is extremely useful, as it combines my speakers, headphones and microphone into a single USB port. A must-have for port-limited plebeians like myself:
m audio
Installation
Installation was very simple: Plug in Aorus Gaming Box power cord > Plug in Thunderbolt 3 Cable to laptop > wait until Windows has installed device drivers > install latest Nvidia graphics drivers > Done. EGPU works with hot plugging and cold plugging. USB peripherals are running perfectly under full gaming load.
I added a TdrDelay ValueData of 10 and a TdrDdiDelay ValueData of 20 in the Windows Registry Editor to allow Windows a longer 'timeout' period for the GPU to respond. It has fixed many crashes and BSOD errors in previous builds, with no downside whatsoever.
I further modified the Windows Registry to add Link State Power Management into my Windows Power Settings
Steps to do these are at https://egpu.io/forums/pc-setup/guide-generic-windows-10-solutions-for-egpu-bsod-crashing-and-system-freezing-link-state-power-management-tdrdelay-tdrddidelay-nvidia-power-management-settings/
I also updated the firmware of the Aorus Gaming Box. This was a bit of a hassle, but I made a guide for updating older Thunderbolt devices with newer laptops here.
Cuda-Z Bandwidth:
Cuda Z  3060 2450
CineBench R23 Single and Multicore:
Cinebench 1559 CROP
Cinebench 6634 CROP
Unigine Heaven Intel Iris iGPU:
Heaven Iris 486
Unigine Heaven Nvidia MX450 dGPU:
Heaven MX450 624
Unigine Heaven Nvidia RTX 3060 eGPU. In terms of raw performance the Asus RTX 3060 Dual OC is essentially identical to the GTX 1080 that came with the Aorus Gaming Box:
Heaven 3060 2363
3D Mark Time Spy:
3DMark TimeSpy 3060 7546
CrystalDiskMark:
CrystalDiskMark
RTX 3060 vs GTX 1080 Benchmark Results
Parformance difference is minimal in Unigine Heaven (DX11) and considerable in Time Spy (DX12):
Heaven 1080 2406
3DMark TimeSpy 1080 6477
Thermal and Power Limits
Intelligent Cooling BIOS Power Profile. (Under this profile PL1 dynamically changes depending on the system load):
HWInfo64 Intelligent Cooling Power Limits CROP
Extreme Performance BIOS Cooling Profile. (Under this profile PL1 and PL2 Power Limits are maxxed out):
HWInfo64 Extreme Power Limits CROP
CPU, GPU and SSD Temperature measurements after 50+ Minutes playing CoD Warzone with Intelligent Cooling Profile:
HWInfo64 Warzone 50 Minutes CPU Temps CROP
HWInfo64 Warzone 50 Minutes GPU Temps CROP
HWInfo64 Warzone 50 Minutes SSD Temps CROP
Lenovo Slim 7i Pro System Information
eGPU Root Complex Expansion:
HWInfo64 Thunderbolt Root Expansion CROP
Thunderbolt Control Centre / Device Manager:
TB Control Centre CROP 2
Device Manager 4 GPUs CROP
One of the most interesting features this laptop has is a BIOS Level Discrete GPU Switch. This disables the NVIDIA MX450 at BIOS Level and is no longer visible to the OS at all. This is extremely useful for an eGPU System where driver conflicts or performance / stability issues occur when a discrete GPU is present. This is an issue I had with my E14, having to disable and then re-enable the MX450 upon a system start. This is no longer the case, and absolutely no software changes need to be made once the dGPU is disabled in BIOS.
20210806 095246 CROP
Another feature that I appreciate is BIOS level Performance Profiles. Under Intelligent Cooling, the laptop runs very quietly and performs almost identically to my i7-1165G7 E14 System in Cinebench. With the Extreme Performance Mode enabled there is considerably more fan noise, but the CPU now outperforms the i7-1165G7 in both Single and Multicore Cinebench R23.
20210806 095330 CROP
The cooling system for this ultrabook is excellent. It is extremely quiet under the Intelligent Cooling mode and keeps CPU temperatures very well controlled.
Yoga Slim 7i Pro Teardown
TH3P4 Thunderbolt GPU Dock Review
TH3P4G2 Thunderbolt GPU Dock Review
Wikingoo Thunderbolt GPU Dock Review
DIY Portable Custom Water Cooled Thunderbolt 3 eGPU
Thunderbolt 4 Docks, eGPU Daisy Chaining and the One-Cable Dream
Windows 10 Solutions for eGPU BSOD, Crashing, System Freezing and Stuttering
Adding Advanced Power Management Options to Windows Laptops for Performance, Thermal Throttling & Power Management
2021 14" Lenovo Yoga Slim 7i Pro (MX450) [11th,4C,H] + GTX 1080 @ 32Gbps-TB4 (Wikingoo eGPU) + Win10 21H1 // Custom Loop Water Cooled eGPU [build link]
pau1ow, goalque, itsage and 1 people liked
Badea Cosmin Gabriel
(@badea_cosmin_gabriel)
Nice review and great upgrade.
2021 14" Lenovo Yoga Slim 7 [11th,4C,G] + GTX 1660 Ti @ 32Gbps-TB4 (CM MasterCase EG200) + Win10 20H2 [build link]
Boltoway liked
@boltoway, Excellent find on the Asus GeForce RTX 3060 Dual OC Edition to work with 1st generation Gaming Box! Your build demonstrates the advantages of eGPU setup perfectly. You get to piece together almost all components that are important to your use.
Boltoway liked
Boltoway
(@boltoway)
ritterbutzke
(@ritterbutzke)
Great Guide! Making me consider an egpu again
Boltoway liked
Boltoway
(@boltoway)
Lycid
(@lycid)
I have the recent Lenovo Legion 7i with the same gen processor. This laptop is a dream to use with eGPU, almost as if it was purpose built for it. For me, the included vantage software has a MUX switch that disables optimus and basically tells the laptop to pretend its a desktop (restart required). This completely removes any driver oddness/stuttering with eGPU use for me that required me to manually disable non-eGPU video cards in device manager to fix. No need for the bios-level switch (but it supports that too). And if I remember correctly, I get almost twice the Firestrike Extreme score on it compared to my 8750H Razer Blade from 2019 on the same eGPU.
Planning on doing a build here soon. But don't have any good games with benchmarks that I play, unless people are cool with just 3D mark scores!
2021 16" Lenovo Legion 7i Gen 6 (RTX3060) [11th,8C,H] + RTX 3090 @ 32Gbps-TB4 (Razer Core X Chroma) + Win10 21H1 [build link]
Boltoway liked
wildfear
(@wildfear)
@lycid
I had the 2020 legion 7i with 10th gen (great device btw) and if you have this version I suggest to disable intel virtualization in bios to get extra boost with TB3/egpu Smile
2022 16" ASUS Zephyrus M16 (RTX3070Ti) [12th,14C,H] + RTX 3080 @ 32Gbps-TB4 (WD_Black D50 * ADT-Link R43SG) + Win11 // inc MSI GS66 12700h numbers as bonus [build link]
Boltoway liked
struthio
(@struthio)
@Boltoway: Do You know if this laptop have PCIe 3.0 or 4.0 for NVME drive ?
Boltoway
(@boltoway)
