configuration:
CPU i9-9900t, PCIe Configurations: 1x8+2x4
2x8gb ddr4
m.2 m key ssd 1tb @ pcie 3.0 x4
integrated GPU1 UHD630 on-chip
integrated GPU2 RX560 @ pcie 3.0 x8
OS: win10 pro for workstation x64 with lastest update
installation:
There's no trick on configuration, just set "AUTO" in BIOS, plug m2 connector into 2nd m-key slot on the motherboard.
Connect external GPU with a display and power on, even no restart required after installing Nvidia drivers.
Here's testing screenshots
settings:
Upload benchmark results, tested twice with external display
That looks awesome! Do you mind providing us the numbers with Heaven 4.0 benchmark, with everything maxed out on 1080p?
.no problem I'll post later
