2016 ASRock Z270M-itx [7th,2C,K] + Quadro K620 @ 16Gbps-TB3 (AKiTiO Node Lite) ...
2016 ASRock Z270M-itx [7th,2C,K] + Quadro K620 @ 16Gbps-TB3 (AKiTiO Node Lite) + Win10 [TobyB] // WX2100, P400, WX4100, RX560, GTX1060
TobyB
(@tobyb)
I bought the Node Lite so I could do some testing with eGPU, I will get a GTX1060 but I can test what I have in my house with it.
PC System
  • ASRock Z270 mITX
  • Core i3-7350K stock speeds
  • 8GB of Cruical DDR4
  • Samsung SSD
  • Windows 10
eGPU gear
Software configuration
I got the latest drivers from the web for all the devices.  It was almost a clean install of Windows 10 latest version.  Initally it didn’t work with the firmware out of the box but with the B1-25+4.4.3 firmware updated it was OK.
Benchmarks with Win10
With video card in PCIe slot
NVIDIA Quadro K620
Unigine Heaven @ 1440x900 = 39.3fps
Cinebench R15 = 87.75fps
NVIDIA Quadro P400
Unigine Heaven @ 1440x900 = 29.4fps
Cinebench R15 = 80.76fps
AMD FirePro W4100
Unigine Heaven @ 1440x900 = 23.2fps
Cinebench R15 = 55.15fps
AMD Radeon Pro WX 2100
Unigine Heaven @ 1440x900 = 37.0fps
Cinebench R15 = 83.19fps
With video card in AKiTiO Node Lite TB3
 NVIDIA Quadro K620
Unigine Heaven @ 1440×900 = 36.5fps Down 7%
Cinebench R15 = 86.61fps Down 3%
NVIDIA Quadro P400
Unigine Heaven @ 1440×900 = 27.6fps Down 6.5%
Cinebench R15 = 71.97fps Down 10.8%
AMD FirePro W4100
Unigine Heaven @ 1440×900 = 22.5fps Down 3%
Cinebench R15 = 53.8fps down 2.5% 7% down
Unigine Heaven @ 1440×900 = 35.1fps 5% down
PCIe Bandwidth tests
AMD W4100 in Node Lite AMD W4100 in PCIe slot
Here the PCI Tree with P400 on it showing the system uses a x2 3.0 low power JHL6240 controller making it a neutered 16Gbps-TB3 link.
Have you posted your Mac mini set up yet? Wasn't able to find it?
Nice. Look forward to seeing the results. Shame tagging doesn’t work on this forum! I’ll keep my eyes peeled.
TobyB
(@tobyb)
PCIe Bandwidth tests added to the opening post.   Sadly I’m getting hard reset of PC, when I connect display to the eGPU and disable the output of video to Intel GFX.
I did a clean install of Windows without ever using the iGPU, now there isn’t crashes so it seems the iGPU doesn’t like the eGPU.  I got the drivers from ASRock website not intel.  The P400 was working too.
I tried to use it in Ubuntu. No go with 16.04 with Kernel 4.10.
TobyB
(@tobyb)
New GPU:  AMD RX560
Unigine Heaven @ 1440×900 = 68.8fps Down 10%
Unigine Valley @ 1440×900 = 65.4fps Down 13%
Cinebench R15 = 117.9fps Down 6%
Unigine Heaven @ 1440×900 = 76.6fps
Unigine Valley @ 1440×900 = 74.2fps
Cinebench R15 = 124.95fps
TobyB
(@tobyb)
New GPU:  nVidia GTX 1060 3GB
Unigine Heaven @ 1440×900 = 142.7fps Down 25%
Unigine Valley @ 1440×900 = 114.3fps Down 21%
Cinebench R15 = 109.40fps Down 5%
Unigine Heaven @ 1440×900 = 190.8fps
Unigine Valley @ 1440×900 = 145.3fps
Cinebench R15 = 114.74fps
(@jason_cheung)
Hi Toby, May I know what's your TB3 driver and NVM version? As i couldn't detect the box, i'm having TB3 15BF driver 17.2.671.250 and NVM 8.
TobyB
(@tobyb)
I used the ver:16.2.52.250 drivers from Asrock site.  I'm not sure what the NVM8 is, I didn't need anything other than the TB Drivers.
Sorry looks like the pictures were deleted from the hosting site I used.  The low power GPU's could be installed in the case without any problems, I just bought a 120W brick to make sure they could get upto 75W.  with the 1060 I had to cut a notch out so the 6pin connector could be fed out the back for the Dell DA PSU, kareon on eBay has the cables.  if you want to close the enclosure then you need to ask him for the special adapter it's not ideal though as it's got no plug so I would stick to a GPU that needs no extra power, which I assume isn't much use for most people.
