2019 15" Clevo P775TM1-G [9th,8C] + RTX 2070 @ 32Gbps-M.2 (ADT-Link R43SG) + Win...
2019 15" Clevo P775TM1-G [9th,8C] + RTX 2070 @ 32Gbps-M.2 (ADT-Link R43SG) + Win10 // custom enclosure
(@aurelius_pontius)
Clevo laptop 15''
i9 9900 cpu
64gb ddr4 2666Mhz
Gigabyte rtx 2070 oc
The egpu encloser is home made,from aluminium and inside of this case,is a Corsair sf600 platinum,so there s no external power supply,and the board in this egpu is a ADT-Link R43SG
The laptop got a bios mod,to support the i9,and the original videocard was gtx 1060 inside of this laptop,but after a while was not working anymore,and then i disabled this in bios and hardware,and i start using the cooler from that card,to the cpu(with some modification).
ddfdfdfdg
Hardware pictures
139212710 2052535344883803 7647406475673947434 n
139626496 404651827428891 1373727935774617664 n
ggggg
139478615 240077934390841 1281498458550154502 n
139886143 859431621509110 5695412919568277725 n
test1
Unbenanntdfdfdfdf
hhffhfh
hghfghj
2019 15" Clevo P775TM1-G [9th,8C] + RTX 2070 @ 32Gbps-M.2 (ADT-Link R43SG) + Win10 // custom enclosure [build link]
Boltoway, itsage, mr.ribeiro and 1 people liked
(@idris_fahmi)
@aurelius_pontius, how did you manage to use the laptop display monitor? or you can just straight up use your laptop monitor right away without any issues?
