I will briefly describe my Egpu build here,
for MacBook Pro 2020, base (8th intel CPU, 16g ram CTO), Razer Core X + Vega 56 reference
<Preperation>
1. Window 10 18362.295 build (not Others)
2. DDU
3. AMD driver(recommended ver.)
4. EFI loader (Link : https://egpu.io/forums/bootcamp/macbook-pro-16-windows-egpu-error-12-fix/ )
Mac OS
- Plug and play egpu and macbook at TB3 slot (next to tab key)
- Enjoy!
Window 10
- Install Window 10 18362.295 build using bootcamp
-window insider (20150) → fail -upper 1903V → fail
- Complete the remaining settings(automatic) in Offline (not Wifi connections)
- Open window 10, Install DDU and → Safe mode (press Shift key and restart button)
- Remove NVDIA & AMD driver
- Restart window 10 (not safe mode)
- Plug eGPU and install AMD driver (error 12 or not)
- Device manager → find RX vega 56(or other GPU) → remove driver (not software)
- Disconnect eGPU
- Open Device manager and disable following pictures (Optional)
-Disable following USB Composite Devices and Light Sensor
10. Boot MacOS
11. Check following steps @aa15032261
1. Download bootx64.efi (v0.5) bootx64.efi.zip
2. Boot to macOS recovery mode (Tutorial)
3. Set Security Boot to "No Security" (Tutorial)
4. Boot to macOS
5. Set the startup disk to macOS (Tutorial)
6. Mount EFI partition using Clover Configurator (Mount EFI -> Mount Partition) (Download)
7. Open EFI disk from desktop then go to /EFI/Boot
8. Rename /EFI/Boot/bootx64.efi to /EFI/Boot/bootx64_original.efi
9. Copy bootx64.efi from step 1 to /EFI/Boot
12. Restart
13. Turn on the macbook pro (NOT!! connected eGPU), press option key to select booting disk
14. Select window partition and see the bootloader
15. Connect in your eGPU to a thunderbolt port (near tab key) then press any key (except z)
16. Check your eGPU running(Fan ON) as well as window loading
17. Disconnect eGPU
18. Log on window 10, then connect eGPU
19. Enjoy!
**Tested**
LG-4K monitor 27"
Mouse : Logitec MX585
Audio : Airpod 2 (bluetooth interrupt to mouse MX585)
Game : League of Legend (4K), Valorant (4K) (Vanguard issue also OK) tested
**Thanks to**
aa15032261( https://egpu.io/forums/bootcamp/macbook-pro-16-windows-egpu-error-12-fix/ )
Cheers for this Pharm,
I have a simular setup 13" 2020 i7 MBP 32gb Core X Chroma +Sapphire Pulse RX5700XT.
I will not be trying Windoze just yet but not getting the full benefit from the card using FCPX its only giving me 35-40%
I have a 7" 4k monitor and mirrored the displays, the monitor I intend to use is out of stock here.
I have heard about using a headless HDMI plug to increase the graphics speed, are you aware of that?
Cheers Zeb
.@zeb, hi, I am adding also @andygev35 and @itsage if they can offer any insight.
I have a similar setup but I feel my cpu is not performing as expected
For example my cpu never runs above 3.6 ghz even in 2 thread test. For comparison my 2018 i7 model runs the same test at 4.4ghz.
In 5 thread test the 2020 model runs at 3.2ghz while my 2018 is more 3.5ghz
I would appreciate you response as I am deciding whether to keep it or send it back.
Can you share some data from a cinebench r20 test ?
Full 8 threads score and av frequency
5 threads average frequency power draw watts and temps
2 threads av frequency power draw
A) 2020 MacBook Pro, i7-1068NG7, 32GB RAM, 1TB, EGPU Razer Core X, Nitro+ RX5700 xt 8Gb, Samsung 49 1440p UltraWide C49RG
Mac OS Catalina 10.15.7, Internal Bootcamp Windows 10 2004 pci.sys swap.
B) 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Razer Core X, Nitro+ RX5700 xt 8Gb, LG 32UK550
C) 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Gigabyte Gaming Box RX580 8Gb, Mac OS Catalina 10.15.2, Ext SSD Windows 10 1803
D) 3.1 GHz I7, 16Gb, 1TB MBP 13 2015 TB2 , EGPU Gigabyte Gaming Box RX580 8Gb
After talking to apple support and getting my performance logs today they came back with their verdict.
Apparently there is a firmware bug affecting the t2 chip introduced with the 10.15.6 update which is the reason for my 2020 mbp i7 underperformance. Supposedly will be fixed in the next update.
