2015 13" MacBook Pro [5th,2C,U] + RX 570 @ 16Gbps-TB2>TB3 (Sonnet Breakaway 350D...
2015 13" MacBook Pro [5th,2C,U] + RX 570 @ 16Gbps-TB2>TB3 (Sonnet Breakaway 350D) + macOS 10.15.6
The-fons
(@the-fons)
My first try, I followed all the guides and hardware.
Hardware:
Software:
Installation:
  1. Placed GPU into Sonnet Breakaway
  2. Connect power from Breakaway to GPU (I forget this step the first try and had to go back into the Breakaway)
  3. Hooked up Digital Display to Sonnet
  4. Hooked up Thunderbolt and Adapter
  5. Followed the steps (super easy) in the purge wrangler setup guide
And it worked right out of the box!
Next try, a Mac mini Late 2012
2015 13" MacBook Pro [5th,2C,U] + RX 570 @ 16Gbps-TB2>TB3 (Sonnet Breakaway 350D) + macOS 10.15.6 [build link]
Matthew Nainggolan
(@matthew_nainggolan)
hey, how well is the performance of the RX 570 on your system? Can you show some benchmark results, thanks
