Regarding my black screen, is it after Windows boot, I get the spinning wheel and Windows starts normally if I type my password, but the screen stays black, even when the eGPU is disconnected. Whether with UEFI or BIOS Windows, it’s like if after installing the eGPU drivers, Windows couldn’t operate without the eGPU.
Nando4>>To answer your question, we don't have much control over problematic hardware until the Setup 1.35 is booted. Black screens before then need to be managed with accurate timed eGPU power on.To get accelerated internal LCD mode use a ghost display adapter and dual-monitor tools (or ultramon) software to start a *Windowed* app on your eGPU, then move it to your internal LCD. Details at:
previous setup : 2013 15" retina Macbook Pro + TB2 Akitio Thunder 2 EVGA GTX 1060 DIY (Mac OS 10.13 and Windows 10)
current setup : 2018 15" retina Macbook Pro + TB3 Aorus Gaming Box 1080 (Mac OS 10.13 and Windows 10)
2013 15" MacBook Pro (GT750M) [4th,4C,H] + GTX 1060 @ 16Gbps-TB2 (AKiTiO Thunder2) + Win10 // Dell S2417DG [build link]
Would you ask his Boot ROM version (under macOS hardware overview) and how many times in a row it works?
Many users have reported that a 750M model has a POST problem:
https://egpu.io/forums/mac-setup/understanding-the-bootcamp-boot-successfailure-logic/#post-94
Some users have had success with the automate-eGPU.sh -a mode:
https://egpu.io/forums/mac-setup/mbp-egpu-detection-issues/#post-1305
It works on macOS, but I doubt how helpful this was on Windows because the -a mode makes the eGPU invisible to Windows with pre-2015 MBPs. Some clarification needed.
This setup seems to work probably because the enclosure is the Thunder2.
It seems the problem is boiling down to the Node with Windows on MBPs with 750M. For the moment, I would advise to wait or reconsider the Node if you are on this model.
Hey guys,
I'm the MacBook user Nando was referring to
I just uploaded the video tutorial on youtube:
So, let me introduce you my eGPU setup, realized on a 2013 15" retina MacBook Pro, model equipped with a dedicated GT 750M.
I am using an Akitio Thunder2 PCIe enclosure and a EVGA Geforce GTX 1060 SC 6Gb.
I wanted to use both internal and external display on my Mac.
I was looking for information during weeks before buying it and wasn’t really sure if it would work as I wanted to. Many people are convinced that using the internal screen is impossible or way more complicated if the Mac has a dedicated GPU.
I spend a whole week formatting and testing, using UEFI, BIOS, considering going back to Windows 7 (not for long)…
I finally used Windows 10 UEFI, the programs rEFInd and GPU-switch and nothing else !
No need for an HDMI headless ghost or any program to spoof the number of screens.
I made a video to show you the whole installation process, my GF did the voice acting as I wasn't convinced by my own
If you prefer a text-based tutorial, here are the different steps:
1) Installation of Windows 10 in UEFI mode
On the 2013 retina Macbook Pro, the SSD is a PCIe model. This seems related to the UEFI mode used by default when using the Boot camp assistant. If you don’t want to use it or are using another model of Macbook, you can follow this excellent tutorial to force the UEFI mode:
http://fgimian.github.io/blog/2016/03/12/installing-windows-10-on-a-mac-without-bootcamp/
You just need to create a conventional partition and convert your table partition from “hybrid” to “protective”. By doing this, Windows will see a GPT disk instead of MBR. You just need to boot your USB drive on EFI mode.
Once Windows is properly installed with the correct Macbook drivers (another reason to prefer the boot camp assistant), you need to go back to Mac OS.
2) Installing rEFInd
rEFInd is a boot manager tool, like rEFIt or GRUB. Its first advantage is the ability to choose the OS without the need to press a key at startup. And the real reason why we are using it is to spoof the computer to allow Windows seeing the entire installed hardware.
You can install refind from this link: http://www.rodsbooks.com/refind/
Then you need to activate this spoof ability by opening a terminal and typing these two commands:
sudo mkdir /Volumes/efi sudo mount -t msdos /dev/disk0s1 /Volumes/efi
Now, you can see your EFI partition in your Finder.
Go to EFI/EFI/refind and open the file refind.conf with textedit.
Search for the “spoof OS version” and remove the comment symbol #
Reboot your computer and choose Windows on the rEFInd screen.
Open your device manager, you’ll see your iGPU (intel iris pro graphics 5200) and dGPU (Geforce GT 750M)
3) gpu-switch
GPU-switch can be downloaded from there: https://github.com/0xbb/gpu-switch
Download the windows version, available in the description
(direct link : https://github.com/0xbb/gpu-switch/releases/download/v0/gpu-switch-windows.zip )
Install Microsoft C++ redistributable (not sure which version do the trick, I’ve installed each version in x64 and x86 just to be sure)
open the file integrated.bat with administrator rights, you should see the word “success”
4) GPU driver installation
Not sure if this step is necessary but I’ve removed the dGPU driver before installing nVidia GeForce experience. The program DDU (Display Driver Uninstaller) is perfect for that.
You can download it using this link: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Choose to uninstall and shutdown the computer, as you will install a new hardware indeed
When your computer is off, plug the power supply to your eGPU, press the computer power button, wait for the chime and the rEFInd screen to appear, then plug your eGPU to the Macbook and launch Windows. If rEFInd is stucked, hold the power button until the computer is off.
You should now see three graphics cards in the device manager, two of them not recognized at this point.
Install nVidia GeForce experience and the latest nVidia driver. The GPU list will be updated at the end of the installation process.
5) Final configuration steps
Re-launch GPU-switch and reboot. You don’t need to unplug the eGPU when rebooting.
Now, your eGPU should have an error code 12, with unsufficient resources available.
Just right clic on the dGPU (GT 750M) and disable it. Re-launch gpu-switch just to be sure (integrated.bat) and reboot.
Just a last step and you’ll good to go
Right click on the nVidia icon in your systray and open the configuration panel. Go to PhysX and set it to automatic instead of processor, like on this picture:
6) Windows startup and shutdown to use the eGPU
Now, the most important part, to avoid screwing your configuration: every time you go back to Mac OS, Windows will switch to the dedicated GPU (maybe also when turning off the computer, I’m not sure).
For this reason, always re-enable the GT 750M before turning off the computer! Otherwise, you’ll get a black screen at Windows startup.
Just follow this procedure when you want to use your eGPU:
- Use gpu-switch to set the integrated GPU as primary
- Disable the dGPU from the device manager
- Turn off your computer or reboot
- When you see the reEFInd screen, plug your eGPU and launch Windows
- Play you favorite video game or launch your intensive GPU application (there are two schools)
- Re-enable your dGPU from the device manager
- Unplug your eGPU
7) Usage comments
That’s it, you can now launch your games on the internal screen or using an external monitor
To switch between both, just plug the display on the eGPU and use the shortcut Win + P (Cmd + P on a Mac keyboard) to toggle between both screens.
You can also duplicate them, it works, but don’t expect any kind of good performances doing this
8) Some advice based on my little experience:
If your end up with a black screen, you can restore Windows to a previous restoration point or remove the display driver. If you really can’t boot windows, using Parallels Desktop, you can boot your Windows partition from a virtual machine, then remove the display driver.
At first, I was experiencing a game crash and the GPU fan running at max speed, when launching any sort of game. This issue was caused by the power supply connection, using an Xbox 360 S adapter with too thin wires
These wires caused a voltage drop when consuming the 100W needed when playing a game (against 15W on Windows)
About the electrical connections, here are a few pictures
I’ve added a connector on the free PCB footprint to avoid soldering wires on the board. The cables are 0,75mm2 section and fits perfectly the original jack hole.
About the PCIe power connector at the top of the graphic card, I had to cut it with a Dremel to fit the enclosure. You can find specific (and pretty expensive) cables on Ebay if you don’t want to modify one.
For the ventilation, a colleague helped me cutting holes in front of the fan. I’m not sure to keep this solution, as some games make it very noisy.
Let me know if this tutorial or the video did help you. Don't hesitate to ask for support if you want to do the same setup.
Some websites are pretty discouraging about the concept of eGPU, the whole process is not pretty user-friendly but I'm happy to see that there is an active community growing each year !
"When your computer is off, plug the power supply to your eGPU, press the computer power button, wait for the chime and the rEFInd screen to appear, then plug your eGPU to the Macbook and launch Windows. If rEFInd is stucked, hold the power button until the computer is off."
This is what happens every time in my case. The eGPU is a 980 Ti and the enclosure an Akitio Node. Do you just retry boot if the rEFInd screen gets stuck?
@matthieuv: Amazing video, very in-depth!
What I observed is that at 3:44 you remove a comment mark which enables "spoof_osx_version 10.9". This workaround is exactly the same as apple_set_os.efi:
The firmware that comes along with macOS 10.12.4/internet recovery of 10.12.3 might not be compatible with rEFInd's spoof_osx_version. Would you check your Boot ROM version under System Report -> Hardware?
As you’ve got it working, your MBP firmware possibly differs from @mac_editor. Or the Akitio Node with TB3-to-TB2 adapter makes the difference.
At least we have narrowed the issue down. For reference, my BOOT ROM version on macOS 10.12.4 is: MBP112.0138.B25. I do, however, use the modified apple_set_os.efi by @goalque to get into Windows with Iris Pro enabled.
Just for fun, I decided to try one last time before returning my GPU (which I shall do within the next two days). I followed the instructions exactly according to the video, with the following exceptions:
- Since I'm running macOS 10.12.4, I have to make use of @goalque's modded apple_set_os.efi file instead of eEFInd's incorporated spoofing service.
- I am connecting the GPU via a TB3->TB2 adapter from an Akitio Node.
- The GPU I am connecting to is a GTX 980 Ti, and not a GTX 1060.
The outcome was as follows:
- The iGPU Iris Pro graphics was activated and I was able to switch to it.
- According to video, I plugged in my eGPU when in the rEFInd Boot Manager (set to boot on integrated graphics by running gpu-switch previously). The rEFInd Manager froze. This could not be resolved on multiple tries.
Because I am unable to boot with the eGPU connected, there is still no detection even after proceeding with these instructions. A great tutorial however! It will be useful for users building with the Thunder2! Kudos!
yours freeze every time ? Mine almost works every time, that's weird :/
I have Mac OS 10.12.3 installed and BOOT rom version MBP112.0138.B21, I didn't know about a compatibility issue with 10.12.4 but that's good to know !
You can try plugging the eGPU before turning on your computer or plug it when running Mac OS and reboot it.
I heard about a software update of the Akitio Node, did you try connecting it without the GPU while Windows was running ?
Or maybe try reinstalling Mac OS to stay on 10.12.3 for the moment
I just found this topic, maybe it could help : https://egpu.io/forums/builds/akitio-node-now-works-in-macos-with-late-2016-macbook-pro/
- macOS 10.12.4 has issues with apple_set_os.efi only, not otherwise.
- Windows 10 does not detect my enclosure even without a GPU, but since it freezes on boot with a GPU installed, it does detect something I presume.
- My Node is on the latest firmware already.
- I can get the setup working on macOS 10.12.3 with 980 Ti. I want to work it out on Bootcamp as well - that's not happened so far.
- Reinstalling macOS 10.12.3 will be too painful for me. I did create an additional macOS partition to test my eGPU out. You can read the implementation and what I've tried so far here: https://egpu.io/forums/builds/2014-mbp-w-750m-akitio-node-w-980-ti-mac_editor/
I am trying a different GPU. If that doesn't work either, then I think my enclosure is not compatible (on Windows) with my thunderbolt firmware.
