Setup & Software Discussions
2013 15" MacBook Pro (GT750M) [4th,4C,H] + RP 580 @ 16Gbps-TB2>TB3 (Blackmagic e...
2013 15" MacBook Pro (GT750M) [4th,4C,H] + RP 580 @ 16Gbps-TB2>TB3 (Blackmagic eGPU) + macOS 10.14.4 [drivec]
drivec
(@drivec)
MacBook Pro (Retina, 15-inch, Late 2013)
Processor: Intel Core i7 2.3 GHz (quad-core)
iGPU: Intel Iris Pro 1536 MB
dGPU: NVIDIA GeForce GT 750M 2 GB
OS: macOS 10.14.4
BlackMagic eGPU (Radeon Pro 580)
Apple Thunderbolt 3 (male) to Thunderbolt 2 (female) adaptor
Apple Thunderbolt (male) to Thunderbolt (male) cable, 1 meter
Hardware pictures
To be added later.
Required: Install purge-wrangler.sh (activate AMD support - option 1)
Optional: Install purge-nvda.sh (for external monitors support - option 1)
To enable eGPU support in apps, be sure to enable "Prefer external GPU" in Finder's Get Info menu on an app-by-app basis.
Some apps will natively see the eGPU and will need to be set in the app's settings (for example, World of Warcraft).
Uningine Heaven Benchmarks:
dGPU:
FPS:36.3
Score:915
Min FPS:11.8
Max FPS:63.4
eGPU:
FPS:65.6
Score:1651
Min FPS:12.5
Max FPS:92.2
LuxMark v3.1:
CPU: 1673
iGPU: 2518
dGPU: 1304
iGPU+dGPU: 3324
eGPU: 13103
iGPU+dGPU+eGPU: 15103
Significant improvement in games on internal display - higher graphics settings enabled and increased frame rate. Tested using Kerbal Space Program and World of Warcraft.
No significant difference in render times in Premiere Pro (when using internal display only).
No significant difference in viewport performance in Maya 2017.
This topic was modified 6 months ago
mac_editor and itsage liked
erhansol
(@erhansol)
hey man,
i have macbook pro late 2013 model too with nvidia gt 750m. i want to choose blackmagic egpu but what about you opinions after some time using it. i need something like plug&play. what are your experiences with it so far?
