I use both Windows machines and Macs for work, and having a portable version of each is extremely useful to me. The last 3 years I've been enthralled with the idea of one Laptop that can do it all, and I've been installing boot camp, parallels, and running Win and MacOS together. In addition I decommisioned my gaming desktop and moved it's video card into an enclosure, and used my Macbook Pros as my primary gaming PC. With the advent of Apple Silicon, all indications were that I would not be able to continue with one Jack-of-all-trades laptop for all my needs, so I went out and bought a Razer blade stealth Late 2020 edition with an 11th gen Tiger Lake CPU and onboard GTX 1650 ti Max-Q. I have tested it out with both enclosure/cards I own and so far setup was easy but there are a few lingering quirks.
Razer Blade Stealth Late 2020 with FHD OLED display, core i7-1165G7 CPU, Geforce GTX 1650 ti Max-Q, 16GB LPDDR4x RAM, 512GB Samsung SSD
EGPU(s): Razer Core X Chroma, Razer Core v2
GPU: (in Chroma) RTX 2080 FE
(in Core v2) Radeon VII
Monitor: Samsung CRG9
1. Hotplugged Core v2/Radeon VII, Card was detected but Error 12 banged, windows requested a reboot.
2. Reboot 1, Card shows up as VGA Compatible in device manager, but no drivers
3. Download latest Drivers from amd.com, install them which prompts another reboot
4. On next reboot Radeon VII active in device manager and external display lit up, everything fully operational.
5. Hotplugged Core X Chroma/RTX 2080
6. Windows automatically installed drivers which are fairly old. RTX comes alive and external display lights up
7. In Device Manager GTX 1650 ti Max-Q is yellow banged, with I believe error 31 (no drivers)
8. Downloaded latest nvidia driver for 1650 ti-Max Q, Installed and rebooted
9. All 4 GPU's (Intel Xe, 1650 ti, RTX 2080, Radeon VII) are active and (mainly) operational
Ok here are some 3Dmark scores:
The Fire Strike says 2080 but it was definitely disabled and ran on the Radeon VII
LuxMark 3.1 Results using all 4 gpu's together:
And some CPU benches also:
Geekbench 5:
https://browser.geekbench.com/v5/cpu/4769879
Attaching both egpu's was more an exercise in intellectual curiosity than practical usage for me since I primarily use the egpu's to game and to have the convenience of a 1 cable solution. I was struck by how easy it was to get them working,especially the fact it had 0 issues assigning resources for 4 gpu's total, compared to the general quirkiness of boot camp. However there have been at least a few quirks:
I get stuttering on the desktop when I close the laptop lid and go into clamshell mode, until I either sign out and sign back in, or disable the Intel Xe graphics. In this state games run fine but desktop animations are choppy and dragging a window around the screen is not smooth.
I get major hiccups in several benchmarks (3dmark, superposition) where they will run for 10s normally then pause for half a second then continue. In order to consistently prevent this from happening I had to disable *both* the Iris Xe and GTX 1650 ti in device manager (and have to remember to enable them later). One unfortunate side effect of this is it makes the internal display run at full brightness, which is probably not good for the long term health of the laptop's OLED display.
As a consequence of disabling the igpu and dgpu in the laptop, 3dmark SystemInfo behaves very unpredictably, sometimes leaving a process behind that chews up ~%20 of cpu usage during the test and skewing the cpu results and the final number. There is a new systeminfo which states that it fixes issues related to disabled gpu's in the device manager, but with the new version installed I was not getting SystemInfo or Hardware Monitoring info in my results and because of this they aren't "valid" and cannot be shared. I will run some tests later today and just grab screenshots of the results if the links aren't viewable.
I've had some stability issues using the RTX 2080 by itself (the Radeon VII has been rock solid but is a poorer performer overall in Windows) , Over the course of 3 days I've had 2-3 freezes just on the desktop, and a couple BSOD's (the BSOD's seem to be related to starting 3dmark with the old systeminfo installed). Using the laptop on its own without the egpu's it has been rock solid stable.
2020 13" Razer Blade Stealth (GTX1650Ti) [11th,4C,G] + RTX 2080 @ 32Gbps-TB4 (Razer Core X Chroma) + Win10 20H2 [build link]
Your 3D mark scores are set to private.
Also, would love to see some game benchmarks. We really need more performance stats on TB4 here, would love to see how it compares practically to icelake or H-series Tb3.
Laptop: Razer Blade Advanced 15" w/ GTX 2060, i7 8750H, 16GB RAM
eGPU: Razer Core x Chroma w/ 2080ti
@lycid, I posted screenshots of the 3dmark results. For whatever reason the links don't work if I disable hardware monitoring.
I've tried running DDU and wiping the Intel AMD and NVIDIA drivers, then reinstalled Intel and nvidia drivers and plugged the RTX 2080 back in. Still encountering random freezes at the desktop just web browsing. Also the usb controllers on the core x chroma are not working after the blade and core x chroma go to sleep and wake back up, sometimes I can disable and re-enable them to get them working but sometimes this doesn't work and I just need to reboot.
As for games, I've only played Elder Scrolls Online, World of Warcraft, No Man's Sky, and Hellblade Senua's Sacrifice. ESO runs *noticeably* better on Tiger Lake than the Macbook Pro 16 i9. This game is notoriously demanding of single threaded cpu performance, and I am seeing at least a 20fps jump in performance pretty much everywhere in game. It hovers around 90-120 fps in the open world and 50-70 fps in cities or large grps of players. The other games look to perform very similarly. Everything runs better than it did on the Asrock Phantom Gaming x570 ITX/TB3.
Awesome to hear!
As far as random freezes, just disable the dGPU in device manager in your laptop when using the eGPU. For whatever reason, windows just doesn't handle 2 eGPU's too well.
That said, on the latest windows update + latest nvidia drivers, this problem seems to have disappeared for me, at least from what I could tell last night when I did it.
Quick update, I ran the stealth for 2 days straight on my desk with sleep disabled and with both the igpu and dgpu *enabled* and had no freezes. I signed out and back in to resolve the desktop stuttering, and didn't run any benches which were exhibiting hitching but did do some gaming which seemed not to be affected. It seems the lockups occur shortly after either coldbooting with the rtx 2080/core x attached, or shortly after hot plugging (about 5-10 min). Most of these times I was disabling either or both of the onboard gpu's so I am trying not to do so to see how this affects stability. One other thing is coldboot always works but I've had error 31 a couple of times after hotplug, which requires a coldboot with the 2080 attached to resolve.
Update to update: Had system freeze about 5 min after I posted this, with all gpu's enabled. Was about 15-20 min after coldboot with egpu attached.
Thanks for all of this excellent info. Sounds like you aren't experiencing the issue where drivers need to be reinstalled for the 1650 each time you plug/unplug the eGPU?
2020 Razer Blade Stealth (1165G7 + GTX 1650Ti Max-Q) + Aorus Gaming Box 1080
Awesome to hear!
100% of the time, your freezes on desktop are due to LSPM set to maximum power savings. Check your power plan and head to change advanced power settings. Look for PCI express and then set both options to off. Had that issue on my razer and Mechrevo. Fixed it in both cases
I do actually have it set to off when plugged in, and it has made no difference.
Playing around to it being off for battery made my battery life significantly worse, no surprise there.
@lycid, Sorry to hear that 🙁 ... I have it set to max power savings when not plugged in.
Not much of an update since I haven't had much time to experiment this last week, but how I initialize the egpu seems to play the biggest role in if I have stability issues.
Boot the Blade Stealth with no peripherals attached, sign in, hotplug egpu -> perfectly stable for days and days.
Boot the Blade Stealth with Core X Chroma attached -> system freezes at desktop within an hour (usually less).
Boot the Blade Stealth with no peripherlas attached, sign in, hotplug egpu, use nvidia widget to disconnect, then re-connect later -> System freezes eventually (was the following morning aftet idleing all night).
