System Specs
- Macbook Pro- 13inch Mid 2012
- 2.4 Ghz Intel HD 4000.
- 256 SSD
- OS Mojave
- Akitio Thunder 2 + AMD RX 570 (DDR5 4G)
Hardware
Installation
STEP 1: Put together Akitio Thunder 2 and AMD Radeon Pulse
STEP 2: Jumper the PSU directly
STEP 3: Connect it all together on the thunderbolt.
STEP 4: Use Purge Wragler script + Set-up egpu Script
STEP 5: Just Restart
Benchmark
Heaven
Internal Display
External Display
Looking forward to modify the Akitio Thunder 2 and the build. Putting it in a case and switch button to power. 2 months in used as for now no issue found.
How are you finding the noise and heat? I love these mini eGPUs but found the card got hot and loud pretty quick...
I don't put it cover and I choose corsair psu which is fine for me. Beside I put it also inside my desk drawer, as for now no noise issue and working fine.
