2013 11" MacBook Air [4th,2C,U] + RX 560 @ 10Gbps-TB1>TB3 (Zotac AMP Box Mini) ...
2013 11" MacBook Air [4th,2C,U] + RX 560 @ 10Gbps-TB1>TB3 (Zotac AMP Box Mini) + macOS 10.13 [betova]
betova
(@betova)
MacBookAir6,1 (11" Mid 2013 MBA)
i5 CPU
4GB RAM
iGPU is Intel HD Graphics 5000
High Sierra 10.13.4
Enclosure: Zotac AMP Box Mini
Video Card: Gigabyte Radeon RX560 (GV-RX560OC-4GD)
Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter
Apple Thunderbolt Cable (0.5m)
Hardware pics
Screen Shot 2018 04 19 at 5.47.02 PM
Screen Shot 2018 04 19 at 9.30.58 PM
Screen Shot 2018 04 18 at 10.25.26 PM
Screen Shot 2018 04 18 at 10.47.47 PM
Screen Shot 2018 04 19 at 9.40.24 PM
1) Updated system to High Sierra 10.13.4
2) Installed PurgeWrangler . Thanks!
https://egpu.io/forums/mac-setup/script-enable-egpu-on-tb1-2-macs-on-macos-10-13-4/
3) Installed automate-eGPU.kext. Thanks!.
Follow instructions below to copy kext, repair permissions, rebuild kext cache.
https://egpu.io/forums/mac-setup/app-automate-egpu-by-goalque/paged/3/#post-33579
4) Put the Video card in the box, plug to the MBA, power on, Ready!
This specific MBA model can't output 4k over TB with OS X (some people report it works with Windows).
Tried all available hacks, unsuccessfully.
My main work computer is a MBP on an LG 4k display, but I switch input to my MBA when I do personal stuff. The change to low DPI resolution was really annoying (even when scaled by the LG). I wanted 4k modes but didn't want to replace my 11" MBA, since it has 256GB SSD and I really like the compact size.
Doing the eGPU is an expensive proposition, when all is done it's about $420 including the Video card, which is close to what the laptop is worth, but I already had the video card and I really don't like the current MB lineup to justify buying a new one.
I noticed some slight video to audio lag when using a USB ethernet adapter, not sure how the bandwidth is shared between USB and TB on this machine, or maybe it was an unrelated thing. I don't notice when I switch to using Wireless LAN. Maybe it's unrelated but can't tell for sure at this point
I really don't do gaming so I can't comment on 3D acceleration, but video seems smooth so far.
Thanks everyone for providing the kext and patches!
Yukikaze and itsage liked
This is a very nice pairing! We’d love to see some photos of your 11″ MacBook Air eGPU setup
betova
(@betova)
Updated OP to template format inc pics.
betova
(@betova)
Updated to Mojave, only re-added PurgeWrangler and it still works fine!  It seems the RX560 gets native support.
kqube
(@kqube)
I have a setup similar to you and I can't get the amp box to boot or being recognized, and is never listed in the thunderblot devices in system information.
Do you had do specific operation to get the box working ? Or did it worked straight away, just with the patches ? Thanks!
betova
(@betova)
It worked right away with the patches.  After upgrading to Mojave I only reinstalled PurgeWrangler.  What brand is your Video Card? Firmware seems important.  Mine is Gigabyte.
