Mini ITX build with support for external GPU?
thomas022
(@thomas022)
So I have the idea of building a LAN party PC in the Velka 3 case with a light weigh GPU inside and the ability to connevt external GPU for heavy lifting when I really need it. I was thinking about using the Ryzen 7 3700x but I'm not terribly up to date on current gen stuff and I read that AMD does not have proper support for thunderbolt 3?
My question is are there any recommendations for a mini itx build with a ballpark CPU and motherboard that will support the use of external GPU?
@thomas022, There's only one ITX motherboard that supports AMD processors and has on-board Thunderbolt 3, X570 Phantom Gaming-ITX/TB3.
Instead of going Thunderbolt 3 route for eGPU, I would recommend going with M.2 eGPU. The performance is better and it's a lower cost overall. You can look into ADT-Link R43SG.
2020 Gigabyte Z490 Vision D [10th,8C,K] + RTX 2080 Ti @ 32Gbps-TB3 (AORUS Gaming Box) + Win10 2004 [build link]
