Hi Guys,
I thought I would share my build.
System specs (15 inch Macbook Pro, CPU: i7, iGPU:- Intel 630, dGPU: Radeon Pro 455, eGPU Radeon 5600 XT Mac OS and windows 10)
eGPU hardware (MSI Radeon 5600 XT Mech OS 6gb with a Razer core X)
Hardware pictures
Mac OS
1. Put 5600 XT in Razer core X
2. plug into Computer running Mac OS.
3. make sure you have a monitor plugged in it just works.
Benchmarks (
Comments (
as you can see from the benchmarks its a massive improvement
The external display connected to the e-GPU cannot be recognized. If I connect the external display through another TB3 prot using an adapter, it works fine. Do you have any ideas about that? Will this cause poor performance?
2016 15" MacBook Pro (RP455) [6th,4C,H] + RX 5700 XT @ 32Gbps-TB3 (Razer Core X Chroma) + macOS 10.15.4 & Win10 1909
