late-2016 13" Macbook Po + [email protected] (AKiTiO Thunder2 via TB2 to TB2 adapter) + macOS10.12.2BETA [theitsage]^
Page 1 / 2 Next
theitsage
Famed Member Admin
November 29, 2016 4:18 pm
I recently got an AKiTiO Thunder3 enclosure. Using it with a Late 2016 MacBook Pro through Thunderbolt 3 / USB-C port presents a few challenges. These MacBook Pro laptops are definitely not going to cooperate with just any Thunderbolt 3 enclosures. We read reports from Razer Core owners seeing the Unsupported status under macOS Thunderbolt connection. It's the same with AKiTiO Thunder3 and likely with AKiTiO Node.
My AKiTiO Thunder2 RX 470 eGPU setup works perfectly fine on this Late 2016 MacBook Pro 13" through a Thunderbolt 3 to Thunderbolt 2 adapter. Ironically AKiTiO Thunder3 (and most Thunderbolt 3 enclosures) with a Thunderbolt 3 cable does not have official support.
We've learned IOThunderboltFamily.kext and its controller file dictate which Thunderbolt 3 devices are supported. Kid2010 on Netkas discovered a workaround to enable macOS support for all Thunderbolt 3 enclosures.
Goalque's trusted automate-eGPU script helps macOS communicate to my RX 470 Thunderbolt 3 eGPU. I can get video output to an external monitor but there's no graphics acceleration or Metal support.
When I tried an Apple flash drive mounted on a PCIe adapter, everything works perfectly through the Thunder3 - full 40 Gb/s 1x through the AKiTiO-supplied Thunderbolt 3 cable. There certainly are more hidden road-blocks on these Late 2016 MacBook Pro in regards to external graphics card implementation.
I installed macOS 10.12.2 Developer Beta 4 last night but there's no improvement. Out of frustration I daisy-chained the Thunder2 enclosure through Thunder3 enclosure to my Late 2016 MacBook Pro for fun.
Check out the bundle of cables and TB3<->TB2 dongle in this setup. To the professionals out there, this is your only way to expand the capabilities of your ultra-thin and sleek-looking MacBook Pro.
94 external GPU build guides
nando4, goalque and t0panka liked
Yukikaze
(@yukikaze)
Prominent Member Moderator
November 29, 2016 6:27 pm
There is someone over at /r/egpu claiming that he has the Razer Core working (I think that is windows only, though, due to the mention of Bootcamp), including internal display rendering. Not sure what to make of that, and I hope he posts the promised update/guide.
My eGPU Zoo - Link to my Implementations.
Arthur44
(@arthur44)
November 29, 2016 6:28 pm
Nice work! Does the Akitio Thunder3 works on bootcamp?
goalque
(@goalque)
theitsage liked
theitsage
Famed Member Admin
November 29, 2016 8:14 pm
@goalque that's awesome! We'd love to see your how-to. Which Thunderbolt enclosure are you using?
goalque
(@goalque)
November 29, 2016 10:33 pm
Might work by installing rEFInd and uncommenting spoof_osx_version config line, or alternatively as I did in EFI Shell:
1) Download apple_set_os.efi
2) Download EFI Dev Kit:  https://sourceforge.net/projects/efidevkit/files/latest/download
3) Format an USB stick in OS X Disk Utility (Choose Erase, Format: MS-DOS (FAT), Scheme: Master Boot Record)
4) Copy apple_set_os.efi to the root directory
5) Create a folder structure in Finder as follows: EFI/Boot/bootx64.efi
where bootx64.efi is the renamed Shell_Full.efi file from /Edk/Other/Maintained/Application/UefiShell/bin/x64/folder
6) Plug the USB stick into the USB-C to USB adapter, and connect it to your Mac (TB3 port closest to the esc key)
7) Connect the AMD eGPU
8) Turn on your Mac and hold the Option key down
9) Select "EFI Boot" with the enter key
10) Change file system to USB “fs2:”
11) Type “apple_set_os.efi
12) Change file system to Windows partition “fs0:”
13) cd EFI\Boot
14) bootx64.efi
15) Wait for the “whoosh” sound!
Should work with the Apple TB3-TB2 adapter and Windows 10 built-in AMD drivers. Not sure if Node or Core are workable.
I have a variety of TB enclosures 🙂
late-2016 13" Macbook Pro nTB + [email protected] (Netstor HL23T) + macOS & Win10
late-2016 13" Macbook Pro nTB + GTX980/[email protected] (Netstor HL23T) + macOS10.13 & Win10
theitsage and nando4 liked
theitsage
Famed Member Admin
December 1, 2016 3:27 pm
I'll give this how-to a try this weekend and report back. Thank you!
enjoy
(@enjoy)
December 1, 2016 4:02 pm
I have mid-2012 Retina MBP with Nvidia GT650M 1GB
 goalque  - can i use the internal display with the steps you post here?
I want somehow to run via my internal display, i want to play on my retina display!
my rMBP 15':
  • 2.3GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.3GHz) with 6MB shared L3 cache
  • 16GB 1600MHz DDR3L
  • 256GB SSD
  • Intel HD Graphics 4000
  • NVIDIA GeForce GT 650M with 1GB of GDDR5
Its still beast with GTX 1080, but i want to play games on my internal RETINA display somehow?
Is this is posible!
I want to do this on Windows 10 via bootcamp or external SSD with windows....
can i use - gpu-switch by 0xbb (to set Intel HD Graphics 4000 graphic as the display's main driver) i only found that ?
 MacBook Pro (Retina, 15-inch, Later 2013) 3.2GHz Quad Core Intel i7-4750HQ / 8 GB 1600 MHz DDR3 / 256GB SSD + 1TB
ikir
 ikir
(@ikir)
Prominent Member
December 3, 2016 2:31 pm
Acceleration with RX 480? Is it already working with 10.12.2?
eGPU.it | LG 34" 4K 34UC88 curved ultrawide display
MacBook Pro 2018 Touch Bar i7 quad-core 2.7Ghz - 16GB RAM - 512GB PCIe SSD --> my Mantiz Venus extreme mod with Sapphire Nitro+ RX Vega 64
December 3, 2016 2:41 pm
Posted by: enjoy
my rMBP 15':
  • 256GB SSD
Is this is posible!
Unfortunately no reports of activating the HD4000 to drive the internal LCD of a GT650M MBP. Next closest option is to buy of build a HDMI/DVI/VGA dummy plug to give a fake LCD  https://egpu.io/forums/mac-setup/turn-your-macbook-pro-to-a-gaming-laptop-with-akitio-thunder2/#post-132
Then can use management software to start ** windowed ** games on the fake LCD and drag them to your GT650M-driven internal LCD.
2018 14" HP Elitebook 840 G5 i5-8350U 16GB 512GB + GTX 1080Ti @ 32Gbps-M2 (ADT R43SG) + Win10
GuideOfGalaxy
(@guideofgalaxy)
December 5, 2016 2:53 am
Posted by: goalque
will this guide work with nvidia graphics cards.
HWfreak
(@dooku655)
December 5, 2016 12:41 pm
Is AKITiO charging Macbook through TB3?
goalque
(@goalque)
December 5, 2016 1:25 pm
Posted by: GuideOfGalaxy
Posted by: goalque
No. I know how:
RX 480: http://www.3dmark.com/3dm11/11748177
GTX 980: http://www.3dmark.com/3dm11/11751133
The EFI app can automate this. The development of the script project has been halted due to thread hijack on TI forum.
EDIT:
It appears that Windows 10 updates has an effect. The above procedure might work with Nvidia cards as well.
nando4 liked
theitsage
Famed Member Admin
December 5, 2016 4:59 pm
Posted by: HWfreak
No it doesn't provide enough power to charge the MacBook Pro. It does make that charging sound when I plug the Thunderbolt 3 cable into the laptop. I'm seeing about 15W through the connection which is right about the rate of power consumption. In the several hours I've used the laptop connected to my AKiTiO Thunder3 + RX 470 eGPU, the battery percentage has stayed at mostly the same level of charge.
ikir liked
ikir
 ikir
(@ikir)
Prominent Member
December 8, 2016 7:51 pm
Tomorrow I will receive my MacBook Pro 13" 2016 and next week Thunder3! I will add my test to this thread.
I plan to build an eGPU with RX480
goalque and nando4 liked
hblockx
(@hblockx)
December 12, 2016 3:37 pm
How did you get rid of the error code 12 in bootcamp?
Dsdt-Override alone doesn't seem to work and setup1.3 does not work with forced gpt of 2016-macbook?
theitsage
Famed Member Admin
December 13, 2016 2:04 pm
I have not spent a lot of time in Windows 10 on this 2016 MBP yet. My focus atm is on making it work in macOS. I've read several reports that error 12 was fixed either through DSDT Override or by Goalque's instructions in post 49.
Which eGPU setup and MacBook Pro are you working with?
hblockx
(@hblockx)
December 13, 2016 8:39 pm
Using the new macbook pro 13 late 2016 with touchbar and akitio2 (thunderbolt 3 adapter) with RX470. Override hasn't fixed it for me, sadly. I haven't tried goalques steps yet but doing it this weekend!
hblockx
(@hblockx)
December 14, 2016 11:11 pm
Sadly hasn't fixed it at all... Windows is not booting with the egpu plugged in, i still have to plug it in right after the Windows-logo. In the end error code 12... Feeling really strange that mac os works like a charm and windows does not, usually it is the other way around with egpu?! 😀
goalque
(@goalque)
December 14, 2016 11:38 pm
@hblockx, I'm sorry to hear that. Seems to mimic 2015 13" MBP's boot behaviour. I've the non-touch bar version of the 2016 13" MBP.
hblockx
(@hblockx)
December 15, 2016 9:17 am
Is there a fix for this? Otherwise i need to build a desktop :'D
Actually the problem is not the boot (i can plug it in later) but then i face the code 12. Is it better @windows with nvidia? Then i am going to buy a 1070... (but i prefer the RX470 because of mac os drivers)
ViDtje
(@vidtje)
December 15, 2016 10:03 am
I have been interested in eGPU's since 2013. Since I got a 2016 15" MacBook Pro, I wanted to build one myself. But I have a few questions I hope you guys can answer. My use case for an eGPU is to connect me triple monitor setup with only one cable. I only plan to use it on macOS, but if it works on Windows, that's a bonus.
Are there any downsides or instabilities I should know about? If I run goalque's script, does everything work? That means just plugging in the eGPU and then booting?
Thanks in advance!
EDIT: I'd also like to say I'm a programmer, so I don't mind fiddling a bit around if that makes the setup more stable.
ikir
 ikir
(@ikir)
Prominent Member
December 15, 2016 11:46 am
Hi! Welcome!
You are adventuring in a dark place, even if there is a lot of experienced users you must consider that you could have issues.
My first eGPU based on Thunder2 was super stable and fast, but i had a Mac mini which is the perfect machine for eGPU imho since there is always a display connected.
For example you can't let your machine sleep. you must reboot when you plug eGPU (for now) and few apps use eGPU on internal screen (Metal and OpenCL) if you want always one acceleration you should have an external display.
Also the entire community was waiting for 10.12.2 released few days ago and a new script form goalque (not yet released). follow these pages and very soon you will know if it is a viable option for you.
ViDtje liked
ViDtje
(@vidtje)
December 15, 2016 11:58 am
Posted by: ikir
Hi! Welcome!
Thanks for your answers! I only want to use the eGPU when I'm at my desk, this means it isn't a problem that it only works on external monitors. Is there any other problem I should know about except for rebooting and not being able to sleep the laptop?  I also  read somewhere that the chance of successfully booting without problems is only 50/50. Is that only on Windows or also on macOS?
On a sidenote, why does sleep not work with an eGPU? Just curious.
theitsage
Famed Member Admin
December 15, 2016 3:04 pm
@ViDtje the best option atm is to build yourself a Thunderbolt 2 enclosure. It has very little difference in performance vs. Thunderbolt 3 enclosures. It's more affordable and proven.
If your plan only involves macOS and external display, I'd recommend getting these parts for your eGPU build: Radeon RX 460 + AKiTiO Thunder2 + Dell DA-2 + custom/pre-made power cable.
Once you hook everything up, goalque's script is all you need to make it work.
nando4 liked
theitsage
Famed Member Admin
December 15, 2016 3:08 pm
@hblockx You'll have a harder time using an AMD eGPU. I've tried both GTX 960 and GTX 980 and they were much easier to get going.
Posted by: hblockx
December 15, 2016 3:09 pm
@ theitsage, you mean a Thunder3? ViDtje had a 2016 MBP with a TB3 port. A Thunder2 would require an additional TB2<->TB3 and give half the bandwidth.
Besides, a AKiTiO Thunder3 is US$249 on Amazon-US and bhphotovideo. Good price.
ikir liked
theitsage
Famed Member Admin
December 15, 2016 3:13 pm
@Nando4 you're right. Sorry I left out the TB3<-->TB2 adapter. I understand there's loss of bandwidth but to make Thunderbolt 3 eGPU work in macOS is not possible atm.
I got the Node last night at 10:30pm and initial testing is not favorable. I will check into it more this weekend before doing a full review of it.
Intel is really keeping a tight leash on certification and licensing on Thunderbolt 3 eco-system. My Dell XPS 13 9350 works flawlessly (plug and play) with the Thunder3 enclosure. Suddenly it's not supporting external graphic card with the Node. This explains why Apple laptop would only connect to Thunderbolt 3 enclosure with TI TPS65983 USB-C controller.
nando4 liked
ViDtje
(@vidtje)
December 15, 2016 3:16 pm
I actually plan on waiting until after CES, just in case some manufacturer makes an enclosure with macOS certification. I also saw that AMD GPU's have better driver support in macOS. The only downside is, since I'm in Europe, I haven't found any resellers of any eGPU enclosure.
Either way, thanks a lot for answering my questions!
ikir liked
hblockx
(@hblockx)
December 15, 2016 3:32 pm
But before there were more problems regarding stability and so on, right? Now it is stable but i cannot get rid of error 12. I think it is somehow my fault but i do not know what i should try next... The macOS support is just amazing on that card 😀
Posted by: theitsage
Mark
 Mark
(@mark)
December 16, 2016 11:20 am
Great job on getting your eGPU to work!
I got mine to work... sort of.
My setup is:
2016 13" MBP with Touchbar
Sonnet III-D with Apple's TB3->TB2 adapter
GTX Titan X Maxwell
OS X 10.12.2
Everything works well, I know I was getting acceleration sometimes as I noticed performance increases in certain games.
However, while my eGPU is plugged in 4k (and sometimes even 1080p60) video lags horribly on Photos, Quicktime and Final Cut, whilst it doesn't on Youtube or VLC. I've disabled the internal screen using DisableMonitor and even that didn't work.
When the eGPU is unplugged 4k video works fine with no lag.
I was wondering whether it's because I have an NVIDIA card and the driver is not playing ball with Metal apps...
Can you please check whether you can play 4k video with the 470 plugged in? You can probably download a sample through a quick Google search or something
EDIT: I think this issue might be better off being on another thread. Not sure whether others have this issue too.
2016 13" MBP with Touch Bar
Sonnet III-D modified with Sonnet SE1 TB3 Upgrade Card and 600W PSU
MSI RX Vega 56 Air Boost OC
OS X 10.12.4
ViDtje
(@vidtje)
December 16, 2016 11:46 am
It appears Asus announced an eGPU case. I wonder if this will work with the 2016 MacBook Pro's. This would be ideal, because it also provides 100w power to the laptop.
ikir liked
ikir
 ikir
(@ikir)
Prominent Member
December 17, 2016 6:30 pm
Posted by: ViDtje
I can sell Thunder 2-3 and Node, but Italian prices are quite crazy
December 22, 2016 3:39 pm
Instructions to fix error 12 on 2016 13" MBP on Windows10 are here.
Posted by: hblockx
hblockx
(@hblockx)
December 22, 2016 3:51 pm
Awesome!
But i bought a 980ti now and this one is working as a charm 😀
December 22, 2016 4:10 pm
That's great news. Would you like to submit an implementation experience report for other 2016 13" MBP owners to leverage off your pioneering work?
Posted by: hblockx
Awesome!
Page 1 / 2 Next
