Custom enclosure? Re-use PC case? Some help finding a case.
Yukikaze
(@yukikaze)
Prominent Member Moderator
So here's the thing. I am looking for a case that can do the following:
1) 4 PCIe expansion slots (1 slot for the eGPU board, 3 for a triple-slot card).
2) Allows for video cards at least 310mm long (think R9 Fury Nitro sized).
3) Will take a standard PSU (Corsair RM550x).
4) Is the smallest possible format that fits the above...
Price? Not really an object (but let's say under 200$ to have a semi-sane upper limit). This will house an eGPU board, a standard PSU and my card.
So far it seems like the Silverston SST-SG10B is the smallest this gets. Does anyone know of any smaller cases that still fit these requirements?
Which Thunderbolt mainboard are you using for this project? If the TBT board has only a couple of ports, maybe you don't need a PCIe rear opening. We'd love to see your planned arrangement of GPU + TBT board layout to visualize what type of enclosure would work.
Yukikaze
(@yukikaze)
I sort of got it to work in place of my Thunder2 setup: The card has a backplate, so it is lying face up on the desk. The TB3 board (Venus) is between the desk and the wall, and the PSU is suspended under the desk (as I've had it before). I am not sure I'll be getting a case at this point, as this takes up very little space.
