eGPU for MacBook via USB to thunderbolt adapter
(@vladimir_vladimirovich)
Can I use pci express x 16 adapter for eGPU with usb output with my MacBook via usb to thunderbolt 2 adapter without any expensive enclosure? Or for example, psi via usb to usb/hdmi adapter to hdmi/thunderbolt adapter to MacBook?
Sorry if its too dump question, but I try to find out why I need expensive enclosure, and what the reason why I can't do it by myself collecting all components separately.
This topic was modified 4 weeks ago
Pending: Macbook air i5 1,8 8gbRAM hd6000
ruslan
(@ruslan)
Not a dumb question - everyone starts somewhere, right?
In short, USB would be way too slow.
USB is 5 gigabits/second, Thunderbolt 2 is 20 gigabits/second, and Thunderbolt 3 is 40 gigabits/second.
And as is, Thunderbolt 3 already limits the eGPUs speed ("bandwidth").
Pending to give context to my posts: Add my system information and expected eGPU configuration to my signature
@ruslan
So enclosure is the only way? No options? Is it possible to plug in directly to MacBook hardware?
padams35
(@padams35)
Just to clarify... MacBook, as in the newish single-port computers that have one USB-C port and nothing else? Sorry, that computer is not compatible with eGPUs. No options.
However if you actually meant Macbook Air (as listed in your signature) then you just use Apple's Thunderbolt 3 to Thunderbolt 2 cable and then run Purge Wrangler or one of the other Thunderbolt 2 enabling scripts.
2011 iMac w/ Sierra, 2015 MacBook Air w/ HS, 2018 Mac Mini w/ Mojave
One eGPU for them all: AKiTiO Thunder 2 w/ RX 460 + 120W PSU
OliverB
(@oliverb)
Posted by: @ruslan
Those statement are not precise. It depends a lot of the application. There are applications/software/games for which 5 GBs is already enough to make a good performance. Some other more limited by the bandwidth and some a less limited.
Posted by: @vladimir_vladimirovich
The PCIe x16 to USB or HDMI risers that exist use a USB cable or an HDMI cable to transmit a PCIe signal. A PCIe signal can come from one of the following: PCIe, mPCIe, M.2, U.2, Thunderbolt. A PCIe signal cannot come from a USB controller or a graphics card's HDMI port.
MacBook has no options for eGPU. The USB-C port only supports USB and DisplayPort signals. An Apple Thunderbolt 3 to Thunderbolt 2 adapter will not work with a MacBook because the MacBook's USB-C port is not a Thunderbolt 3 port. The MacBook doesn't have any connectors that can source a PCIe signal.
MacBook Air has Thunderbolt port (since 2011). This is probably the only option for eGPU.
I don't understand what the following terms mean:
  • pci express x 16 adapter for eGPU with usb output
  • usb to thunderbolt 2 adapter
  • psi
  • usb to usb/hdmi adapter
  • hdmi/thunderbolt adapter
Please provide links for those items.
