Hand-built Metal case for EXP GDC
IgorGIV
(@igorgiv)
 Hello everyone!
Here is my fully hand made from aluminium case. All i need is to make cover and then paint it with black color. (how can i attach more then one file?)
If you never ask, then you will never learn
golden_alchemist, rena-s, 3RYL and 5 people liked
ikir
 ikir
(@ikir)
Prominent Member
[Please login to see this]
my awesome Radeon VII eGPU
deplomb
(@deplomb)
Amazing work IgorGIV.
Would you share some specs? Like actual size, what gpu and used materials etc.
Sky11
(@sky11)
Hi Igor,
what connection do you use - is it TBT3 or TBT2?
what's the GPU?
IgorGIV
(@igorgiv)
Hello! Thanks for your interest!
First i apologize for my English, but i'll try to be as understandable, as i can, and answer all your questions.
There are two types of photos: with new GPU - GTX1060 6G (windforce) from GIGABYTE, and old broken GPU without a cooler (these photos were made much more earlier and i posted them for you can see my case in perspective).
So, as i said, now in my hand-built case you can see mPCIE version EXP GDC 8.3 (so i connect it to my laptop Lenovo Y580 via mPCIE) . The sizes of this case are: 350mm *160 mm * 160 mm. All cases that i saw before has two critical lacks - you need to place somewhere PSU for your eGPU and use small size videocard. And i decided to make all-in-one case in which you can put any standard PC PSU and GPU (even long size, about 330-340mm) together. So i wanted to make it universal.
I used aluminum corner 2m * 10mm * 10mm and one aluminum corner 1m * 10mm * 35mm for chassis, and 3 steel perforated plates for bottom (sorry, i don't remember their sizes, but a had to cut them to fit my case), and 1 sheet of aluminum 500mm * 200 mm * 0,8 mm which is used for dividing PSU compartment form GPU compartment and for front of the case. I also use 4 rubber stands (if you want i can post their photos later). All these i fastened with rivets. And for stretching wires from PSU to GPU compartment i used rubber rings (bought them in store for cars tools, DIY and so on).
If you have any additional questions feel free to ask.
3RYL liked
deplomb
(@deplomb)
Thank you for the details.
looking forward to see the cover.
markozutic
(@markozutic)
hi, what is the thickness of the aluminium sheets you used? in milometers? Smile
2011 15" ASUS K53SV (GT540M) [2nd,4C,Q] + GTX 750 Ti @ 4Gbps-mPCIe2 (EXP GDC 8.4) + Win10 // modified enclosure [build link]
IgorGIV
(@igorgiv)
The thickness of the aluminum corner is 1.0mm, and of the aluminum sheet, as i said earlier, is 0.8mm.
mikke_120
(@mikke_120)
Hello IgorGIV,
I love your hand-build case for egpu. Do you mind sharing with us the final photos of your egpu case?
I'm interested in the cover.
rena-s
(@rena-s)
 Hello everyone!
Thanks to the author for a photo. Also built from Alluminum parts, profile of IKEA.
