Razer Core X - Custom Water Cooling Loop - EK Fluid Gaming - AMD Radeon Vega 56
Alexander Preston
(@alexander_preston)
I upgraded the GPU in my primary rig, so I had a Vega 56 with an EK fluid gaming water block sitting around. My MacBook Pro could use a GPU so I paired the Vega with the Razer Core X. The blower cooler wasn't getting the job done, so I decided a custom water loop was the way to go. So a cheap aluminum radiator off Amazon, some fitting and an EK pump later I have a slick water cooled eGPU.
For the pump I used an EKWB EK-XTOP SPC-60 PWM
For the radiator I picked up a cheap aluminum one off Amazon for $20, a uxcell model.
The Vega 56 water block is the EK-AU Fluid Gaming model.
The loop works great, the temps sit at 59-60 degrees C under a full stress load, and the setup is virtually silent.
And yes it all fits into the housing! I had to swap the 45 degree fitting coming off the GPU (pictured) for 2 90's to make it all work. The hardest part was getting the air bubbles out of the loop, but the T fitting worked well enough.
The_Livy and itsage liked
@alexander_preston Excellent work making everything fits inside the Razer Core! How do you secure the radiator?
Alexander Preston
@itsage
I didn’t secure it, just rolled the dice and slid it all into the case. I don’t move the eGPU around, it just lives on my desk, so it should be ok.
lilipeipei
(@lilipeipei)
Amazing job!
I'm wondering how did you control the pump speed? Or did you just let the fan and pump run at a constant speed? Does the pump stop when MBP is sleeping?
MBP15 2016 configured to Radeon Pro 460 (burning a hole on table when driving my 4k monitor
Razer Core X Chroma (USB ports sucks, but it has RGB!
Radeon VII (anyone could stop these fans?
