selfmade aluminium eGPU chase
tune-fg
(@tune-fg)
Hey guys,
i just want to share my custom build of my eGPU chase which i have made of aluminium.
It fits to my mac design 😉 and houses all regarding components
IMG 1236
IMG 1234
IMG 1233
IMG 1237
IMG 1229
IMG 1228
intruder, ytrox, ikir and 16 people liked
ddqp
 ddqp
(@ddqp)
nice work
Late Macbook Pro 2016 13' touch bar + AKITIO node + GTX 1050TI 4G Windows
Username
(@username)
Nice work done there!
enjoy
(@enjoy)
Great case, clean design....
You can also make it mini and with great front if you use external PSU, but this is the best Thunder2 custom case with big PSU inside Smile
2012 13" MacBook Air [3rd,2C,U] + GTX 1060 @ 10Gbps-TB1 (AKiTiO Thunder2) + macOS 10.12 // external HDD Windows [build link]
ed_co
(@ed_co)
Looks awesome!! Much better than an external brick!! Have you used something as a base, or you build it from scratch?
2017 15" MacBook Pro (RP560) [7th,4C,H] + GTX 1080 Ti @ 32Gbps-TB3 (Mantiz Venus) + macOS 10.13 & Win10 [build link]
mcarver316
(@mcarver316)
Whoa! Nice.
Very professional looking. You could make some nice change with this. Smile
2015 17" MSI GT73VR 6RF Titan (GTX1070-SLI) [6th,4C,H] + GTX 1080 Ti x4 @ 32Gbps-TB3 (AKiTiO Node) + Win10 [build link]
igerard
(@igerard)
Something I don't understand, the case that you build, are they mod of an existing commercial enclosure ? If not, where do you get the necessary electronic board, PCIe slots and TB3 card ?
Regards
MBP 2018, Touch Bar, i7 2.6 GHz, 32 GB RAM, 1T SSD, Radeon 560X... very nice!
eGPU : Akitio Node + RX 580 + GTX 980 Ti + Vega64
Posted by: igerard
Regards
The AKiTiO Thunder3 PCBs were removed and then mounted in this custom chassis with it's own internal PSU. This is a slimmer enclosure than what the eGPU-specific enclosures offered by AKiTiO/Sonnet/Mantiz/Asus : https://egpu.io/external-gpu-buyers-guide-2017/#tb3-enclosures
While the Thunder3 is cost effective to allow such mods, it's TI82 firmware does not allow non-eGFX certified hosts to allow eGPU detection.  The aforementioned TI83 firmware enclosures do have firmware updates allowing eGPU detection on non-certified hosts.
igerard
(@igerard)
Thank you for the answer.
I was believing that having some PCIe board with two slots, one with a TB3 pcie card and the correct power supply would work... Something I don't understand in fact is a need for a specific additional electronic...
With the price I will try the last Akitio Node with the TI83 chip then... I believe
igerard
(@igerard)
And the setup shown here would be perfect for me :  https://egpu.io/akitio-node-review-the-state-of-thunderbolt-3-egpu/
I am a programmer and need to test some stuff with Cuda, does not need the most powerful and expensive card Smile
