So I had an idea and slapped it together... Dankitio Node?
rb6freak
(@rb6freak)
So I had an unused Dan A4-SFX case and I'm tired of my ugly steel Akitio Node.  I took apart the internals of the node and put them in the Dan A4-SFX case.  All that was needed was some motherboard stand-offs and drilling of the holes.  Looks pretty decent.  Anyways I thought I'd just share it with the community.  Pics below.
2020 17" Dell XPS 17 9700 (RTX2060) [10th,8C,H] + RTX 2080 Ti @ 32Gbps-TB3 (AKiTiO Node) + Win10 [build link]
Username, Eightarmedpet, itsage and 1 people liked
@rb6freak This is excellent! Was the SFX power supply able to fit on the other side?
2019 13" MacBook Pro [8th,4C,U] + RX 5600 XT @ 32Gbps-TB3 (VisionTek mini eGFX) + macOS 11 & Win10 2004 [build link]
Noble Member Moderator
@rb6freak
How do you have a spare Dan case kicking  about?!
That is a great mod though, and actually a better size than most eGPUs, if I was made of money I'd be tempted ted to do the same (or maybe with a Ghost case).
rb6freak
(@rb6freak)
@itsage Yes the PSU fit with ease. I forgot to include a photo of that installed so I updated the post. I'm trying to look for options for an IO shield (even though there's only 1 port), perhaps a solid black piece of cardboard or plastic cut to shape.
@Eightarmedpet Cheers, lol.  Well I had a build in that case but it ran too hot, so I moved it over to a Louqe Ghost S1 chassis.  Yes the Dan case is really small, even smaller than the Akitio Node which I'm all about.
@rb6freak
Nice! How are you finding your Ghost? I’ve just bought one to ride me over until Apple updates the small MacBook.
rb6freak
(@rb6freak)
@eightarmedpet
Love it. It's my sons gaming build. Totally awesome building experience.
