Under desk mounts for Mac Mini and eGPU
Willem
(@willem)
Hey guys!
Can you share advice to desk mount a Mac Mini and the eGPU under a desk?
I have reached out to 4 brands/companies who build enclosures and got only 2 responses. And those 2 weren't helpful. 🙁
For the Mac Mini itself I looked around but only found product with pictures from the previous generation Mac Mini. Or just a velcro thing with which I don't feel comfortable at all!
I was hoping there's some builds out here who have attached an enclose for the eGPU and the Mac Mini below a desk.
Mac Mini 2018 | 3,2 GHz 6-Core Intel Core i7 | 16 GB 2667 MHz DDR4
Willem
(@willem)
Small bump - hope that's OK. Just to prevent this thread from getting buried. Hope someone can help!
@willem, go to the hardware store. Buy some stuff. Then assemble your custom under desk mounting solution.
UberNiK
(@ubernik)
Do you have a 3D printer?
I could possibly design something for you if you really can't find a commercial product available.
Do you already have an eGPU or are you building one?
Dell Inspiron 15 7577|dGPU GTX 1060|eGPU Custom enclosure GTX 1080
Noble Member Moderator
@joevt, correct answer as ever.
I have under desk mounting but its with the String Shelf system and its a very very small desk suitable for a small London (UK) terrace house alcove, if I had the option I'd have a big desk.
joevt liked
