Will a Thunderbolt hub (not docking station) with thunderbolt logo on it works f...
Will a Thunderbolt hub (not docking station) with thunderbolt logo on it works for eGPU?
b n
 b n
(@b_n)
Hello,
This is my first post here.
I am currently thinking of setting up a ADT-Link R43SG-TB3 behind a Thunderbolt 3hub. for my MacBook Pro.
I want to do this because I want to be able to just plug in once (gpu with monitor/mouse/keyboard) whenever I want to use my Macbook Pro as a desktop with my monitors. And when I want to use my Macbook as mobile device, I can just unplug the hub once.
So my question is will this kind of Thunderbolt 3 hub works with eGPU?
https://www.anker.com/products/variant/powerexpand-direct-7in2-usb-c-adapter/A83710A1
Other alternative:
https://www.aliexpress.com/item/32961693920.html
The setup I'm thinking will be like this
macbook→ thunderbolt hub → mouse/keyboard/egpu → monitor
I'm thinking that the hub uses two TB ports of macbook, so maybe it can work?
Thank you
This topic was modified 6 months ago
b n
 b n
(@b_n)
Seems like this is possible:
https://www.reddit.com/r/eGPU/comments/af36ff/usb_c_hub_egpu_external_mbp13/
Sorry for duplicate question:
https://egpu.io/forums/mac-setup/usb-c-hub-egpu-box/
@b_n, both of those are USB-C hubs with Thunderbolt 3 pass thru so connecting any Thunderbolt 3 device such as an eGPU should work.
One port from the MacBook Pro is used for the USB-C hub. The other port is used for Thunderbolt 3 pass thru (including power delivery).
