Wooden EGPU Case, KFA² Geforce 960, EXP GDC, Dell DA-02
Rik600
(@rik600)
Hello togehter,
I like to show you my wooden eGPU Case.
I wanted it to be as small as possible, so i made a 3d-Model and cut it with from 4 mm wood with a laser cutter.
Afterwards i grindet and oiled it.
It works perfectly with a dell DA-02 Power Supply and gives my Lenovo X220 an enourmus Boost.
Best regards, Hendrik
IMG 2873
IMG 2867
gtx960
Case
T430up, tygpu, Koohyaar and 13 people liked
Outstanding!
Rik600 liked
deplomb
(@deplomb)
excellent job!
Very cool design with the laser typo engravings and the offset for the exp. and psu sockets.
moekloar
(@mo3klo4r)
looks really nice! i also want to build a wooden case. How do you open the case to insert the card? How did you fix the card inside? I mean that little screw-hole for attaching it normally in a computer case? what 3d program did you use? Could you eventually post some more pictures?
adrianr
(@adrianr)
Very neat, and compact - well done! I like this.
HP Spectre x360 13 2017, Apple TB3-TB2 adapter, Akitio Thunder2 boards in an old ATX case, Seasonic ATX PSU, Geforce GTX 1060 3GB
