2019 HP 15-DA1 (8th,4C,8H) + RX 580 @32Gbps running into x2 problems ADT-Link R4...
2019 HP 15-DA1 (8th,4C,8H) + RX 580 @32Gbps running into x2 problems ADT-Link R43SG
lhikary
(@lhikary)
Hey guys
Would appreciate some help here
My eGPU is connected to the nvme slot but on GPU-z it shows that it's running x2 instead of x4
I disabled my dGPU which was running at x4 but my eGPU is still not running at x4
Anyone get any suggestions?
Specs
i5-8265u
32gb ddr4 2666mhz
Nvidia mx 110
MSI RX 580
External 144hz 1080p monitor
@lhikary, Did you confirm the NVMe slot was running at x4 with a har drive prior to using the eGPU adapter? Use other software than GPU-Z to see if that's the real link speed. I'd recommend trying AIDA64 and HWiNFO64.
lhikary
(@lhikary)
Posted by: @itsage
it says its running at Drive Controller: NVMe (PCIe 2x 8.0 GT/s)
NVMe Version Supported: v1.2
How bad is that?
This post was modified 2 months ago
@lhikary, Can you take another screen cap with the Toshiba AIS, Device ID: 0113 selected? Show the information on the right column too. If possible, expand the rest of other PCI Express Root Ports.
lhikary
(@lhikary)
Posted by: @itsage
Thank you for your help
this is with the GPU installed
@lhikary , strangely HWINFO64 is showing your BUS as x4 but your eGPU running at x2.  Suggest use isopropyl alcohol to clean your RX 580 slot pins, the ADT-Link R43SG slot and the M.2 eGPU adapter edge connector and the slot pins. Allow to dry and retry to see if the card now runs at x4.
lhikary
(@lhikary)
@nando4, i changed the gpu entirely and it's still at x2
Looks like the M.2 port is configured as x4 but is only wired for x2. You can confirm by benchmarking a superfast SSD like a Samsung 970 EVO  and seeing large block transfers being limited to x2 3.0 transfer rate (16Gbps).
