Setup & Software Discussions
beast v8.4 random display driver crash p...
beast v8.4 random display driver crash please help!
tolyaba1
(@tolyaba1)
Feb 11, 2017 2:34 pm
Hi I'm using clevo 150hm with 560m onboard I dotn have integrated intel gpu.
So couple of week ago I fired up my egpu with gtx 960.
I ether had error 12 or 43. Right now if I don't use setup 1.3 I'm getting error 43. But I guess its the dual driver problem.
there are 2 ways I can fix it.
1. I set mpci gen 1 to gen 2 then F3 and restart that makes my pc work and windows starts on external monitor which is nice. But I get nvlddmkm.sys error. even if I'm not gaming.
its usually happens every hour. I tried everything you could find on the internet like other drivers, performance settings, tdr delay in registry. I even flashed new bios to mobo and gtx 960..... no result.  I get random black screen for 1-3 seconds then it resets and works again.
2. I just do pci compaction (without the gen2 settings) in the 1.30 setup and it works fine no crashes at all.  But my Ungine score goes down from 1000 to 900 and I notice big frame drops in games because of the bandwidth I gues...
So the question is why is gen 2 connection gets instable every hour ?? only thing I could think of right now is the faulty cable. When I twist it a little bit at the end of hdmi head my screen goes black with same nvlddmkm.sys error, but it stays black waaaaay longer(10-15 sec) then when I get the usual error while using my machine(1-3 sec). Its same 4101 event in windows event log though.
Please help me diagnose this or suggest something to try.
thx
tolyaba1
(@tolyaba1)
Feb 12, 2017 1:42 pm
I think I might fixed it. Found enough info on the forums about the gen 2 problem with beast.
So.... for anyone who has display driver crashes AKA black screens for 1-3 seconds change the following:
NVidia panel > set up digital audio > HDMI > turn this @!#@$ audio off.
tolyaba1
(@tolyaba1)
Feb 12, 2017 9:12 pm
Ehm it helps a bit better I gues but stil I get display crashes and I'm 100% sure it has to do with the electricity.
Every time my display went off I heard a weird sound from my mini fridge, which stand next to me. I thought it might be coincidence, guess not.
Today I turned off my light in the room on and off very quickly, guess what happened... yep display driver crash. So wtf is going on..... how can this thing be so electricity sensitive.
Or is it my old power supply ? any thoughts?
(@uday_bath)
Mar 22, 2018 7:35 am
yes yes same with me bro didi you fixed the problem same with me whin I off the my fan same happens
is ther any solution for this problem
Gh0s
 Gh0s
(@gh0s)
May 22, 2018 6:25 pm
been having same issue yes its with electricity voltage nothing wrong with your psu, it needs a really stable voltage there is nothing you can do about it so far in my 10mounth experience.
kamuk
(@kamuk)
May 12, 2019 9:36 pm
same prooblem. everytime I hear air conditioning fans stop(-as they do when they reach their target temperature-) I get the nvlddmkm.sys error and blue screen of death. I can say it happened %100 everytime. Pretty consistent huh. I don't know how to fix it though.
(@fuumar_hudson)
Jun 13, 2019 12:04 pm
anyone find a fix for this ? I turn off my light then boom it will crash and reboot and sometimes stop working all together
(@fuumar_hudson)
Jun 14, 2019 6:01 am
it seems moving other house hold products like (light, heater and air conditioners charger cabke) to a different outlet did the trick cause it hasnt turned off by itself at all today once it did that
