Which card is the best for Lenovo Z50-70 with Core i5-4210U?
Hope for fast response
NVidia GTX9xx cards are good for you. Avoid GTX10xx ones: https://egpu.io/forums/expresscard-mpcie-m-2-adapters/nvidia-is-killing-off-mpciengff-m2-egpus-error-43-with-372-90/
Thank you very much 😀
I think the only way to connect the eGPU is via NGFF and you will get bottlenecks on the PICe adapter (up to 2.5Gpbs) so I would settle for a GTX 750 or a RX460.
late-2016 13" Macbook Pro + GTX980@16Gbps-TB2 (TB3 to TB2 adapter) (AKiTiO Thunder2) + macOS 10.12.3
late-2016 13" MBP + Quadro M2000/FirePro WX5100/GTX750-TB3 (AKiTiO Thunder3) + macOS 10.12.3
(Custom Thunder cables)
2016 13" MacBook Pro [6th,2C,U] + GTX 980 @ 16Gbps-TB3>TB2 (AKiTiO Thunder2) + macOS 10.12.3 [build link]
Oh and by the way, is there a really high difference between gtx 750 Ti and gtx 960? Maybe there is a good site to compare any cards?
.Try GPU boss: http://gpuboss.com/gpus/GeForce-GTX-960-vs-GeForce-GTX-750-Ti
Also keep in mind that you have to power the GPU so check the power usage of the card. If its under 120W, you can use a regular 12V 10A source. If its below 220W go for the Dell DA-2. If exceeds 220W, go for an ATX source. For example the 960 uses around 100W while the 750TI is reported to be around 60W. But for a 970/980 you would need a Dell DA-2 source
Power supply you say, I have some Corsair power supply left over, it's 350W I believe, should I replace it with sth weaker?
.Should do it
Looks like not much of a difference, lol
.I mean, 750/960
