Cheapest way to get NGFF cable (I already have the GDC beast with an mPCIe cable...
Cheapest way to get NGFF cable (I already have the GDC beast with an mPCIe cable)
Ajayajayaj
(@ajayajayaj)
All the NGFF cables I can find are 30$ or 40$, which seems overpriced compared to the price of the whole package. Is there somewhere to get this cheaper?
Thanks
2011 15" Asus U57A + GTX1050@4Gbps-mPCIe2 (EXP GDC) + Win10 [no guide]
Cheapest A/E key cables and eGPU adapters found are linked in the buyer's guide:
https://egpu.io/external-gpu-buyers-guide-2018/#m2-interface
If you find anything better then please post.
B Wesley
(@b_wesley)
Links to PCE164P-N06 for M.2 A-E go to a Russian Site that has delisted its product ( https://egpunotebook.ru/component/kabeli/cable_ngff ) and apparently refused to sell to Americans, before that.
Any other leads on products for A-E M.2 over USB --> PCIe Risers?
Sys1: MITX Desktop in InWin Chopin
i5-4570 + 1060 6GB + PCIe 1x adapter (over USB3.0 copper)
Sys2: Dell 15 Latitude 3542
i3-4030U + 1060 6GB + mPCIe adapter for PCIe 1x (over USB3.0 copper)
Sys3:Dell 14 Inspiron E5450
i7-6500U + 1060 6GB + NGFF M.2 A/E --> mPCIe adapter
Sys4:Pending
@b_wesley, there is A-E to M key adapter you might consider trying.   Though only see it on Taobao-CN:
https://item.taobao.com/item.htm?&id=580788189786
There you'd buy an accompanying low cost x1 M.2 eGPU adapter such as the US$7 one or ADT-Link one:
https://egpu.io/external-gpu-buyers-guide-2019/#m2-interface
This may be OK for Gen2. My testing at Gen3 sees it surge-slow-surge so is not Gen3 reliable.
B Wesley
(@b_wesley)
Hey, @nando4! Big fan, and I've deleted the rest of my post because it was off the original topic. I'll find a suitable thread to resurrect or else I'll start a new one, but long story short *thanks* for the link, and to confirm have you had *any* results (even if just PCIe 1x) with that kind of A/E key adapter in the mix?
If so, that's VERY encouraging to hear. 🙂
Rereading your post more closely, I'll look for any other distributors to buy and ship the A-E --> M Key adapter, and would report back results... but likely takes months before anything conclusive if I need to order from Ali or TB.
Sys4:Pending
B Wesley
(@b_wesley)
@nando 4, I got a friend to pick up a couple of those A/E --> M adapters you mentioned from TaoBao about 15 minutes before he boarded a plane to the States, and I was delighted to install and benchmark, this evening. Pleased to report success.
I also tested the following Amazon part over the weekend, for A/E --> mPCIe ( https://.amazon.com/gp/product/B07JFYSNVL/ ) and it likewise worked.
The bad news is, I'm experiencing microstuttering in Overwatch (my drug of choice) regardless if I sustain north of 60 or even 80 FPS. I theorize that there's latency in travel to/from the device at the end of the layers of PCIe adapters, but I don't know where to begin to devise a test. It's fine in most games and most folks might not even notice, but I tend to be very persnickety about FPS and feedback.
So, now folks with A/E ports have two separate choices for getting their GPU online with an M Key or mPCIe adapter.
Thanks for pushing me to try another layer. I think I might pick up a few more similar keys that are available domestically to test across my machines.   Next step will be drafting build guides, and possibly scripting a few YouTube tutorials.
Sys4:Pending
nando4 liked
B Wesley
(@b_wesley)
Soooo ... I dremeled the A-E Key adapter down to *nothing* (pictures later, in my build guide) including the a bit of the solder points to get a better fit and a more *flush* connection.
And the machine works flawlessly, no more stuttering. It's passing my Passmark stress tests and everything I throw at it. I'm very excited. It's unfortunate that the A-E Key adapter doesn't have wider distribution. HOW RARE are A-E slots?!? you'd think folks would be all over these low-profile adapters like a fat *me* on cake.
Sys4:Pending
Lal Singh Bisht
(@lal_singh_bisht)
Hi everyone,
I have an expresscard to hdmi connector that i wan't to exchange with NGFF to hdmi.
If anyone interested than comment your mobile no here.
@lal_singh_bisht, see EXP GDC A/E M.2 (NGFF) cable .
Lal Singh Bisht
(@lal_singh_bisht)
@nando4, Thanks for reply Actually these websites are not delivering in India. I puchased with the same website but they delivered me a wrong cable (Expresscard cable) they refund me half of amout, but I have a NGFF Slot in my laptop, so I wan't to exchange with my Expresscard to hdmi cable with NGFF to hdmi cable or i need a DIY Solution for connection into ngff port.
