Share:
Dell E5430 + GT 740 with EXP GDC v8.4 Express Card -> Help !
Marsil_Novitio
(@marsil_novitio)
April 19, 2017 8:35 pm
Hi guys,
I am new to the egpu world.
This is my first post, I apologize for any mistakes.
My system:
Dell E5430 i5 3340m
EXP GDC v8.4 Express Card + Dell 8 pin 220w power
GT 740 gddr5 Zotac.
List of steps I've made:
1. Connected gpu + exp gdc + notebook
2. Power on
3. Black screen of the handset, but I hear the sounds of windows.
(Powe off ... alt + f4 then enter :))
4. An external monitor is connected
5. Power up
6- The external monitor displays windows
7. Install drivers
8. Reboot
9. Few seconds after entering windows, the video stops responding. (No sounds hear)
(Power off ... this time need force it)
10. Set 6 seconds delay on exp gdc.
11. Turn on only notebook display (no ext. Connected)
12. Windows starts
13. Device manager shows GT 740 but with error 12.
14. Try this guide: https://egpu.io/forums/pc-setup/fix-dsdt-override-to-correct-error-12/#post-734
But when I try to compile the dsdt, I always get some errors I do not know how to fix it.
For Intel Method I get: syntax errors, unexpected parseop .. etc etc
For Microsoft Method i get: AR00 is not a method, ESEL is not a method, etc. etc
Any help you can give me is well accepted 🙂
Thanks so much!
Quote
April 20, 2017 4:21 am
Posted by: Marsil_Novitio
A pre-compiled Dell Latitude E5430 DSDT override and it's source exists already in eGPU.io's repository. This can be tested or the source used to generate your own DSDT override:
https://egpu.io/public-repository-egpu-dsdt-overrides/
2018 14" HP Elitebook 840 G5 i5-8350U 16GB 512GB + GTX 1080Ti @ 32Gbps-M2 (ADT R43SG) + Win10
Marsil_Novitio
(@marsil_novitio)
April 20, 2017 10:20 am
Posted by: nando4
Thank you very much for your reply!
So, can I compare my dsdt-modified.dsl with the pre-compiled Dell Latitude E5430 DSDT and change the lines where I find the errors?
April 20, 2017 10:28 am
Usage instructions (compare or use) for the pre-compiled DSDT overrides are on the linked page:
Marsil_Novitio
(@marsil_novitio)
April 20, 2017 12:28 pm
Posted by: nando4
Okay, changing some parts I've been able to compile!
Now I have large memory shown in device manager! 😀
One doubt: I did this without egpu connected and without drivers installed.
Now I'm downloading the drivers and proceed with the installation.
Is it the same? Or did I have to compile the dsdt with the connected video card and the drivers installed?
Marsil_Novitio
(@marsil_novitio)
April 20, 2017 6:16 pm
another fail:
1) connect gpu and start notebook
2) installed driver
3) restart
4) Login windows and i think "Work!!"...but
5) after 10 sec pc crash and give this screen:
IMG 0458
If disconnect gpu, notebook boot fine and work...
Any idea?  🙁 🙁
Is possible to reset DSDT? Restore original? (Before Mod)
Marsil_Novitio
(@marsil_novitio)
April 22, 2017 6:44 pm
UPDATE:
I formatted the system and tried the procedure from the beginning.
Now I have wide memory, gt 740 recognized and nvidia working panel.
I can start the FurMark and Unigine Valley.
But...Whatever I do, after 10 minutes of starting, the video freezes.
No black screen, simply remains fixed image of what I was doing. Need force power off.
I also have a strange dsdt, it has two sections with QWord. With only one section does not work.
Any help? Thanks!
Attached some screens
large
dsdtscreen
wimpzilla
(@wimpzilla)
April 22, 2017 7:39 pm
Hello,
I suggest you to avoid FurMark stress test on an eGpu solution, it is a lot of stress for at the end nothing, instead go on valley, 3DMark and other games, bench, like you said.
Asking full consumption/load from the VRM stage is not the best even for a 740. Your adapter/gpu could not enjoy the current peak. ^^
E=Mc²
wabash1
(@wabash1)
March 20, 2019 2:35 am
Hello!
I apologize for bumping this old thread but hopefully this will assist anyone else that sees this from google.
I am suffering from the following error when following your guide that you linked:
Intel ACPI Component Architecture
ASL+ Optimizing Compiler version 20161222-32
Copyright (c) 2000 - 2016 Intel Corporation
Compiler aborting due to parser-detected syntax error(s)
dsdt-modified.dsl 2477: ECRW (If (PM0H)
Error 6126 - ^ syntax error, unexpected P
ARSEOP_IF, expecting PARSEOP_CLOSE_PAREN or ','
dsdt-modified.dsl 2481: }) = Zero
PARSEOP_CLOSE_PAREN
ASL Input: dsdt-modified.dsl - 12510 lines, 393885 bytes, 4609 keywords
Compilation complete. 2 Errors, 0 Warnings, 0 Remarks, 0 Optimizations
When modifying the file I was able to get it down to 1 error but it seemed to be wrong. This is on windows 7
See the following DSDT: https://www.sendspace.com/file/a9liya
Thank you for any help you can provide!
i7 Vpro Dell E5430
8GB RAM
GTX 660
wabash1
(@wabash1)
March 20, 2019 10:15 pm
I probably did this wrong, I fixed the error by the following code:
 If ((PM6H == One))
CreateBitField (BUF0, \_SB.PCI0._Y0C._RW, ECRW) // _RW_: Read-Write Status
Store (Zero, ECRW)
If (PM0H)
CreateDWordField (BUF0, \_SB.PCI0._Y0D._LEN, F0LN) // _LEN: Length
F0LN = Zero
If ((PM0H == One))
CreateBitField (BUF0, \_SB.PCI0._Y0D._RW, F0RW) // _RW_: Read-Write Status
F0RW = Zero
Ran into an asterisk error and a upper case error for a HID, I made those changes and compiled
ASL Input: dsdt-modified.dsl - 12513 lines, 393896 bytes, 4609 keywords
AML Output: dsdt-modified.aml - 42314 bytes, 1397 named objects, 3212 executa
ble opcodes
Compilation complete. 0 Errors, 14 Warnings, 78 Remarks, 109 Optimizations, 2 Co
nstants Folded
i7 Vpro Dell E5430
8GB RAM
GTX 660
binarytornado
(@binarytornado)
March 22, 2019 2:44 am
I too am having issues with the error 12. Here is my setup:
Windows 10 Pro (up to date)
8GB RAM, 128 GB SATA HD
Dell E6500 Latitude
I have tried the instructions for Intel and Microsoft solutions and was not able to use "find" function in notepad++ to locate the information it specified. None of the searchable fields find the specified text to make the changes needed. The computer boots fine and sees the video card connected to the expresscard interface but won't work due to error 12 listed on the video card in the device manager
Please help!
Thank you,
