Delta 450w for GTX 780?
Edward09
(@edward09)
hello everyone
Like the title, I have an ATX psu Delta 450w. So Is it possible to run comfortably my eGPU beast 8.4 with a gtx 780 on it?
dani29m
(@dani_tx)
I just looked at the spec. on that PSU and it looks like you wont have sufficient Amps. for that particular GPU,which is only 15A single rail as well as double.GTX  780 indicates MAX Power at 250W so divided by 12V equals to 20.8A though normal usage will be more like 16-17A which still exceeds what the PSU can offer.Also looks like it comes with only one 8 PIN connector and you'll need additional 6 PIN to power the gpu.You can of course try it and see,worst case scenario you might experience sudden shutdowns due to not enough power.
