Share:
eGPU not utilized on internal screen unless extending with external monitor
Adrian2JZ
(@adrian2jz)
March 14, 2019 11:10 am
I'm having an issue where my eGPU does not get utilized by games unless I have external monitor plugged. If I have a external monitor plugged in to eGPU, I can extend monitors and then I can use internal monitor. There was a trick where you could put a resistor in the DVI port and trick the card into thinking that there's a monitor plugged in but I can't find it, or maybe someone else has a different solution?
Quote
