EXP GDC + GeForce 8800GTS + Lenovo R60 + Lubuntu 18.04.02 - Was working Nice - N...
EXP GDC + GeForce 8800GTS + Lenovo R60 + Lubuntu 18.04.02 - Was working Nice - Now Problems
herrwaldos
(@herrwaldos)
So I have:
Adapter: EXP GDC  Beast v8.5c - internal mPCI NGFF Mini-PCIe cable to 'HDMI' connection
Card: GeForce 8800GTS
Laptop: Lenovo R60, 3GB RAM, 120GB SSD
OS: Lubuntu 18.04.02
Power: ATX PSU 400W
Game: Mount & Blade: Warband, Steam Native Linux version
So I got all the stuff, connected the EXP, etc, etc - All worked nice - with default linux configuration - no additional tweaking - all good - plug and play.
Warband was playing nice for a while - fough some Looters etc, etc - then my laptop hanged.
After restart all worked nice.
Idiot me decided to install more recent Nvidia drivers from synaptic - all hell - nothing works - error - beeb beep.
Tried official Nvidia drivers - more bs and hell - more beep beep.
Reseted back to default built in linux nvidia drivers - aka the 'nouveau' drivers - ok - sometimes loads to black screen with mouse cursor - can not get anything else - sometimes more beep beep.
So I think I have either:
- Broke up the card with faulty drivers
- Broke up the mPCI NGFF Mini-PCIe - HDMI cable whilst installing and pluging-unpluging.
- The EXP adapter is faulty or broken
TL/DR: All worked good, installed recent Nvidia drivers, nothing works! Morale - if it works - enjoy - If it is not broken - no need to fix it!
Was working only briefely, now solving, maybe Expresscard cable will do...
Adapter:
EXP GDC Beast v8.5c - internal Mini-PCIee cable to
'HDMI' connection
Card: GeForce
8800GTS
SSD
Power:
ATX PSU 400W
herrwaldos
(@herrwaldos)
I am thinking to get an EXP GDC ExpressCard extention cable thing. Will it work with the mPCIe NGFF cable EXP GDC board that I already have?
Adapter:
'HDMI' connection
Card: GeForce
8800GTS
SSD
Power:
ATX PSU 400W
Nick Vasey
(@nick_vasey)
Posted by: herrwaldos
Yes -- being as the adapter stays the same and it's the cable's connection-type to the laptop that can vary -- that should be fine, by my reading.
herrwaldos
(@herrwaldos)
Posted by: Nick Vasey
Right, I also think it is probably the same box, just diferent cabeling to laptop. I am inclined to give one more try. Ill get the ExpressCard+Cable thing next month and update how it goes.
Adapter:
'HDMI' connection
Card: GeForce
8800GTS
SSD
Power:
ATX PSU 400W
herrwaldos
(@herrwaldos)
So whilst loading Ubuntu in recovery mode - so it shows active loading log text - I can see that the Video Card is detected through mPCIe - however the log shows something similar to this:
Card detected
Link up
Link down
No Link
Card detected
Link up
Link down
No Link
Card detected
Link up
Link down
No Link
 etc, etc, etc... and it goes like this on - all the loading time, eventualy the system loads, if it loads, and I may log in.
I guess - maybe - the cable is faulty, bad connection with the socket, the connection is weak, signal interference...
Adapter:
'HDMI' connection
Card: GeForce
8800GTS
SSD
Power:
ATX PSU 400W
Armin b
(@armin_b)
Read this https://egpu.io/forums/expresscard-mpcie-m-2-adapters/mpcieecngff-m2-resolving-detection-bootup-and-stability-problems/.
You might want to try isolating your cable that goes from EXP GDC with 3mm of aluminium foil. Connection with egpu seems unstable. Also try to run the expresscard in gen 1, setting in BIOS.
HP Elitebook 8570p i73630qm + 8GB RAM + Nvidia GTX 660 ti OC + 400w Be Quiet E9 PSU
herrwaldos
(@herrwaldos)
Posted by: Armin b
Thanks for your input, ill try this later.
Adapter:
'HDMI' connection
Card: GeForce
8800GTS
SSD
Power:
ATX PSU 400W
herrwaldos
(@herrwaldos)
So I isolated the cable, like a nice looong silver space joint for cosmik snoopdogg, but still no good, the same errors.
I think I have damaged the cable before - It was going out through a hole back under where the battery is - pressed between edge of laptops frame and keyboard - probably that damaged the cable - there was now kind of a 'hump' at the contact location between cable and laptop.
I was originally supposed to have the Expresscard version, but I missread the products description on ebay and bought myself the mPCIe one - which I tried to install and screwed up.
Thanks for the help, anyway!
Adapter:
'HDMI' connection
Card: GeForce
8800GTS
SSD
Power:
ATX PSU 400W
